Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 76
Thread: Everything you wanted to know about the G8 diff and half shafts
    Clarks Summit, Pa.
    Maybe so. I'm gonna see what the blower does for me, if that's not enough I'll be poking hard at this again.
    lol
    Is that a euphemism for something?
    lol
    Plastic Cuttin' Bad Ass!
    Central Florida
    lol
    lol
    Wasn't meant to be but kinda comes off that way
    These rears appear to be as strong if not stronger than the GTO rears so I think they will do pretty good.
    The only weak area I see are the axles. They are not any larger in diameter than the GTO axles.
    I'll probably offer a 300m axle and some heavy duty driveshafts in the near future.
    Gforce Engineering
    LIFETIME WARRANTY!
    The Leaders in IRS Drivetrain Technology
    gforce1320@gmail.com
    www.Gforce1320.com 316-260-8433
    http://i25.photobucket.com/albums/c9...honenumber.jpg
    Clarks Summit, Pa.
    Quote Originally Posted by GFORCE1320 View Post
    How about an option to use new shafts with the stock ends for cost savings? Would something like that be feasible? Would that make difference or are the stock parts too weak?
    That's exactly what I was thinking of doing. I can build a set with 300m axles and start swapping them out.
    Gforce Engineering
    LIFETIME WARRANTY!
    Clarks Summit, Pa.
    I haven't re-installed my stock axles yet.
    Let me see how quick I can get some 300m axles ran through the machine shop. You might have to be my first customer.
    Gforce Engineering
    LIFETIME WARRANTY!
    I've been talking to Harrop about getting some gears for the G8, I'll keep you all posted on what I can dig up.
    Gforce Engineering
    LIFETIME WARRANTY!
  9. #19
    I am in talks with a rep at ZF and they are going to look into different gears for me.
    Gforce Engineering
    LIFETIME WARRANTY!
  10. #20
    Beyond Help jbradsh1's Avatar
    Smile
    Ok guys, I've tore down the new G8 rear assembly I got and I must say. GM did a much better job on the G8 then they did on the GTO.
    First off the half shaft dia is about the same as the GTO but the inner stub axle is much larger as can be seen compared to the GTO inner stub.
    They also used a speed sensor in the hub instead of a reluctor ring on the inner stub (big improvement)
    I'll add more information here when I get the diff tore down to see what makes it tick.
    Thanks for this information. I think you just put a lot minds at ease.
