Results 1 to 10 of 14
Thread: Help! Key is stuck in ignition
    Oct 2010
    Default Help! Key is stuck in ignition
    Help! Key is stuck in ignition, i can turn the car off but cant turn it past the point to release the key. Anyone run across this?
    2008 G8, Vararam, Kooks and Hptuners 336 RWHP, 355 RWTQ
    2002 Forumla 701rwhp
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    Just a guess, but I've read of some people having issues with the shifter linkage. If the transmission isn't in park, or if the computer doesn't think it's in park, then the ignition cylinder won't let go of the key. Here are a couple of threads about stuck keys, both were caused by the shifter in some way:
    http://forum.grrrr8.net/showthread.php?t=27053
    http://forum.grrrr8.net/showthread.php?t=14217
    Len
    WNY
    Battery dead/ disconected?
    2009 SBM G8GT (Garage Queen)
    Jan 2010
    Also could be a bad relay in the shifter/key system.
    Oct 2010
    i got it out, no real tricks, i was about to put the car in the garage, turned it off and the key came out. strangest thing
    VIP Member The Yeti's Avatar
    Sep 2009
    East Bay Cali
    My car sat a a GM dealer for a week because of this. Ended up being a bad relay after checking every possible solution. It kept getting worse over the course of a week. Sometimes it would take the car 10 min before it would finally let my key go.
    Pat G Tune & DOD cam, Rick C TB, LSA, Ported Heads, Circle D 2600 Stall
    OBX Exhaust, SLP UDP,H&R springs, Koni Shocks
    BP catch can, BMR Bushings/suspension/chassis
    V Brembo's, Slotted/Drilled Rotors, 3.27s Gears
    Bolt ons Street tires
    12.649@107.817 60ft 1.96 Da 700ft
    Heads/Cam pre stall Street tires
    12.16@114.21 60ft 1.75 Da -200
    After Stall
    11.82@115.9 60ft 1.66 DA 400ft
    Zex 125shot
    11.48@124 60ft 1.83 DA 2000ft
    Beyond Help SRG963's Avatar
    Charlotte NC
    as mentioned above, make sure your battery cables are tight.
    Trigger
    PRAISE THE LOWERED
    Jan 2011
    Alabama
    One came through our shop recently with this issue and it was a faulty relay as mentioned by The Yeti. There is an accesory relay labeled "r8" in the fuse block thats on the drivers side of the vehicle that controls power to the ignition lock cylinder solenoid. When the relay fails you wont be able to remove the key. If it happens again just swap it for one of the relays around it and see what happens. If it releases then you found your problem and its a cheap fix.
    Sep 2009
    Northern Kentucky
    Have you tried playing with the steering wheel?
    Jan 2017
    Default Key stuck in ignition G8 CHANGE THE R8 RELAY IN FUSE BLOCK NEAR PEDALS
    Quote Originally Posted by 02NBMFormula View Post
    Don't go to mechanic, they'll take a few grand out of you before they figure it out. This part is $5!!!!!!
    This is how I fixed it.
    Order https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Omron G8V-1C7T-R-DC12 (1 pc) AUTOMOTIVE RELAY
    Needed tools
    (1) Mobile phone/flashlight to see
    (2) above listed part
    (3) needle nose plyers.
    Pull the little kick plate near the pedals in the driver's side.
    look at the plate you removed and find R8.
    Replace that fuse.
    pull your key out.
    Important to note that I had noticed when holding the brake and did the sport shifting in manual that it didn't always change the gear properly before I did this, will check and possibly update.
