Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Help! Key is stuck in ignition
    Dec 2009
    I had this same issue. Turned out to be the R8 relay also.
    Arlington Heights, IL
    Also had this problem and found the solution here. The relay also feeds the outside mirror motors so turn the key back on and try adjusting a mirror. If the relay is bad they won't move!
    PBM #608 of 888 -- All Stock!
    Beyond Help texn884's Avatar
    Helotes, Texas
    Nice find and fix
    Dec 2021
    There’s a black cylinder on the side towards the dash of the ignition cylinder you’ll see a needle like pin in the center pull that while turning the key back that should do it
