VE Series 2 tank straps are Part Number 92250928.
They're cheaper to buy in USA than in AU.
2011+ WM Chevrolet Caprice PPV should have these 92250928 tank straps.
VE Sedan and WM Sedan (in equivalent years) both use the same tank straps.
There's a guy on another Forum who says his 2011 Caprice in USA has the brackets for mounting aero panels on his tank straps.
Now the question is why are the 92250928 and 92420237 straps different?
Rear left and right Chevrolet SS deflectors are on order and should be here by Monday
any updates on this ?
when i saw the 14 SS i did notice they dont use the oil pan plate , but ive considered putting everything on mine since seeing it
Paul do you know the torque specs for the oil pan protector plate bolts?
Tim
2009 PSM GT Fully Loaded
GM Sirius Connect SIRGM2L - INSTALLED (No more XM!!!)
Fasterproms Ported Intake Manifold w/LS3 TB
Camaro Brembo Brakes @ all 4 corners
Complete GXP Suspension Swap
GXP Axle-Back Exhaust w/x-pipe
Hacked Atari 3 Gauge Display
Superchips Cortex Tuned
Vararam Ram Air Intake
OEM Bluetooth Add-on
BMR Front Swaybar
HSV Valve Covers
20" Camaro Rims
Vector HSRK
6k HID's
Danger to manifold!
Sent from my HTC M7 using Tapatalk 4
2009 G8 GT MSM, Sport Pkg
Rotofab, Magnuson TVS1900 w/3.3", Ported Blower Tub, PB 10% OD 8 rib
Blitz Ls250 heads pocket ported w/LS3 valves, PSI 1511ML springs, YT 1.85 RR, 7.450 PR, Comp FSL AFM cam
Kooks 1-7/8 mids, Corsa, ZL1 converter, PPV alt
