hey paul any info on this?
can you get it?
can you get it?
+1
ProCharger F-1D
Treadstone TR1235 FMIC
Kooks 1 7/8 LTH
Corsa catback
New Era (228/240) cam
Yella Terra 1.7 Rockers
GMPP LS3 CNC heads
Aeromotive A1000 fuel pump
FAST fuel rails
FAST FPR
FIC 1000cc injectors
Yank SS2800
Camaro trans pan/filter
Earl's trans cooler
RX catch can
EFI Live 736 RWHP/642 LBFT 91oct 15psi
EFI Live 730 RWHP/621 LBFT E85 13psi
EFI Live 695 RWHP/603 LBFT E85 11psi
HP Tuners 762RWHP/646LBFT E85 9psi
That may even work with my secondary pump setup and comepletely hide it
Sent from my iPhone using Tapatalk
Tim
2009 PSM GT Fully Loaded
GM Sirius Connect SIRGM2L - INSTALLED (No more XM!!!)
Fasterproms Ported Intake Manifold w/LS3 TB
Camaro Brembo Brakes @ all 4 corners
Complete GXP Suspension Swap
GXP Axle-Back Exhaust w/x-pipe
Hacked Atari 3 Gauge Display
Superchips Cortex Tuned
Vararam Ram Air Intake
OEM Bluetooth Add-on
BMR Front Swaybar
HSV Valve Covers
20" Camaro Rims
Vector HSRK
6k HID's
Yes I can get the parts, we've already done the oil pan protector plate.
Freight to USA will probably cost more than the parts themselves. Anything over 105cm in length has to go DHL/Fedex etc and they don't charge on weight for light items.
I'll get the bits together into a pile and work out the damage in the next few days.
Makes me wonder now if some of the movement I feel at 65-70+ mph at cruising or above is actually turbulence from under the car.
Is that possible?
I would think it could be considering that most higher-end sports cars come with some sort of underbody aero panels. Are they doing that for the rare 200 mph blast or even just for the daily highway commute?
Helps for gas mileage too???
PAUL: are they plastic?
R.I.P. Charlie
"Any man's finest hour, the greatest fulfillment of all that he holds dear, is that moment when he has worked his heart out in a good cause and lies exhausted on the field of battle - victorious." - Vince Lombardi
2009 G8 GT, MSM/Onyx, Prem, Mods: few......Dozen
SWEET I bet you might gain a lil gas milage! how much?!
09.1 G8 GT, 20x9/10 Red G wheels, magnaflow catback, DT's, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP rear diffuser, BMR strut bushings/cradle inserts, BMR sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel.
http://i92.photobucket.com/albums/l4...psce2f18b1.jpg
Looks good. Wonder if an enterprising individual might make something like this with some ABS sheet and some fasteners.
2008 GT - 2300 Maggie, Comp cam, ARH LTs, staggered Breyton GTS, 6spd Manual conversion DONE!!.
From previous owner: 552 RWHP, 589 RWTQ; Tuned by Patrick G via EFI live Autocal
Interesting as hell but the shipping is gonna kill it I suspect.
