Page 15 of 15 FirstFirst ... 5131415
Results 141 to 145 of 145
Thread: Build thread for rebuilding the 6L80
  1. #141
    Tucson
    depends. if you are going completely stock around 2K. more if the solenoid/valve body need replacing. if you start putting in other parts such as a Camaro pan, stronger intermediate shafts, new pumps, etc. it can go over 4K. but with the basics 2k give or take a couple of hundred dollars. pace performance used to have a smoking deal. a new transmission at 1500 plus 100 shipping. now it is 2k plus 100 shipping.
    2009 g8gt - rotofab cai, ported throttle body & FAST intake, 1 7/8s kooks shorties with 3 inch exhaust. 3600 circle D triple disc stall and tranni cooler, udp, hoosier 17 inch drag radials. 223/235 cam/gmpp Heads. HP Tuners. 416 with 11.3 to 1 compression.
    best time: 11.47 @ 118.7 3000 feet da
    best top end 119.4 4000 feet da
  2. #142
    Lucky SOB G8GT721's Avatar
    MA
    I have a Century built and will be swapping to all stock clutches with one extra. I think I read a post that says I don't need to machine anything if century built previously. What are the clearances?
    2008 White Hot G8 GT
    SLOWHAWK Tuned
    My Garage
  3. #143
    I rebuilt mine myself and for the 3-5-R pack I went with between .050 and .080 if I can remember right. Thats using stock clutches, taking out the waved plate, and machining the clutch stand. You may want to ask Rick C or Century to verify.
  4. #144
    MA
    I pmed g8-4spd last night that's rick c right?
    Sent from my iPhone using Tapatalk 2
    SLOWHAWK Tuned
    My Garage
  5. #145
    Apex, NC
    Quote Originally Posted by G8GT721 View Post
    Correct; Rick is G8-4-Speed.
