Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: Stock Subs Wired Incorrectly from Factory!
  1. #51
    Nov 2009
    Maybe this will help check to see if it's wired right before cutting or soldering.
    So I checked this out and everything ohmed out to what the diagram says. My question is should I reverse it or leave it now.
    G8 GXP PSM M6 Stock for now
  2. #52
    Sep 2009
    VT
    It's not like swapping wires in hard, takes few minutes. Swap and have a listen - go with which you feel sounds better.
    Sport /Premium
  3. #53
    Apr 2017
    Sterling, Virginia
    Thank you! This made an unbelievable difference in my G8's low frequency response.
  4. #54
    Nov 2017
    IL
    So, there's adjustments that can be made on a stock amplifier? I have a 2008 G8 GT, and would like to check this out. I never knew there were adjustable points on the stock system! Sweet!
  5. #55
    Just feel for the dial on the bottom of the amp by the battery.
  6. #56
    Junior Member bhunter0830's Avatar
    Feb 2018
    I did this and it’s night and day difference. I switch the wires and turned the amp up to 75% (guesstimate). It’s not like having a sub in the trunk but definitely makes a difference from the factory set up!
