Supposedly 92228638, 92217146, 92219491 these parts numbers are for the 2 gauge set and 92228599 is the three gauge from GM I personally have 92228638, 92217146, and both are 2 gauge
Thanks for the reply. I believe WhiteAutoMedia can (re)program 92228638 and make it have a three gauge display. I g___gled GM 92228599 nothing pertaining to a gauge display came up.
He can he just did one of mine great Guy! I will say buy new and you save from him
Sent from my SM-G900T using Tapatalk
Thanks again. back in the day it seemed these displays weren't readily available. Now gm online sources they have them.
Just know you will still need to order 92182437 its the wire harness for the Atari gauges
I think I have your g8
I bought it from a guy in New Orleans named scott
Anyone happen to know if it is possible to obtain the honeycomb for the hood scoops by themselves? I really have no urge to purchase the whole setup.
Worst case scenario, I pull the mesh out and make the scoop functional? Maybe cool down the LSA IATs some.
Is there a part number for the engine harness connector that attaches to the coolant temp sensor? 2008 G8 GT. The sensor itself is 12608814, but I need a replacement plug to splice into the harness. Apparently the wires going into that plug got pinched back when I did my engine swap, and the damage is too close to the connector to easily repair. My temp gauge is on the fritz, and the radiator fan doesn't always come on when it's supposed to.
Frank, try this repair harness.
For L76 engine.
GM Part Number 88987993
might also be AC Delco PT 1798
Thanks, Paul! That looks like it.
