Noticed an oil leak coming from the rear of the end, put some dye in, pulled the tranny and noticed that wasn't coming from the rear main or the oil pan gasket. Pulled the flywheel and notice the dye coming from the screw holes on the crankshaft (flywheel screw holes)!!!! I didn't know that the flywheel screw holes on the crankshaft are actually true holes (from one side of the crankshaft all the way to the other side). So my thoughts were that this needs to be sealed properly, meaning that when they replaced (dealer) the rear main seal, they reuse the flywheel screws and did not seal the threads properly. But this was about 7k miles ago... so im wondering if crankcase pressure is the culprit of this, but then i realized that it would have been the case, it would have blown the rear main seal before leaking from the screw holes, maybe is one of those go through the path of least resistance if you will. Have anyone experience this before? Also, if anyone could post a pic of the crankshaft by itself, rear view picture.
