Results 1 to 1 of 1
Thread: Grrrr8 parts list Automatic transmission
    Default Grrrr8 parts list Automatic transmission
    AUTOMATIC TRANSMISSION
    5L40-E for V6
    96042712 Detent Plate
    96042860 Extension Housing
    96042861 Extension Housing Gasket
    96041851 Extension Housing Seal
    96042983 Flange
    96042984 Flange
    96042986 Gasket Kit
    8654701 Magnet
    96042963 Main Control Valve Body
    96042540 Neutral Safety Switch
    92191948 Oil Cooler Inlet Hose
    92191949 Oil Cooler Outlet Hose
    96041864 Oil Pan Drain Plug
    96041849 O Ring
    90528145 O Ring
    8677884 Output Shaft Bearing
    96042945 Overhaul Kit
    96042793 Plug
    10478146 Pressure Control Solenoid
    90528145 Seal
    96041866 Shift Control Solenoid
    96041860 Speed Sensor
    96042599 Torque Converter Clutch Solenoid
    96043233 Transmission
    96042971 Transmission Case
    92196977 Transmission Control Unit
    92191917 Transmission Oil Cooler (V6 Radiator Assembly)
    96042545 Transmission Oil Filter
    96043177 Transmission Oil Pan
    96042862 Transmission Oil Pan Gasket
    96042847 Wiring Harness
    5L40-E for V6 ... Converter,Pump, & Clutches
    96042809 Center Support
    96042806 Direct & Reverse Clutch
    96042700 Direct Clutch Hub
    96042807 Forward Clutch Assembly
    96042698 Input Sun Gear Shaft
    96042702 Intermediate Clutch Hub
    96042704 Low Clutch Roller
    96042841 Output shaft
    96042808 Overdrive Clutch Drum
    96042707 Reaction Carrier
    96042705 Thrust Bearing
    96042708 Thrust Bearing
    96042701 Thrust Washer
    96042971 Transmission Oil Pump
    6L80-E for V8
    17803868 Transmission
    Case,Converter & Oil Pan
    24226788 Extension
    24228886 Extension Housing Oil Seal
    24242341 Manual Detent Lever
    24236927 Seal Kit
    24239789 Torque Converter
    24236932 Transmission Oil Filter
    24239528 Transmission Oil Pan
    Clutch Assemblies
    24224724 Center Support Seal Ring
    24238004 Clutch Hub
    24233732 Clutch Hub Thrust Bearing
    24224164 Clutch Hub Thrust Bearing
    24236874 Input Carrier
    24224404 Input Sun Gear
    24224405 Input Sun Gear Bearing
    24239392 Output Shaft
    24224668 Output Shaft Thrust Bearing
    24224188 Thrust Bearing
    24232409 Thrust Washer
    24238905 Turbine Shaft Thrust Bearing
    Control Valve
    24232240 Control Valve Body Lower
    24231442 Control Valve Body Upper
    24242938 Shift Switch Assemby
    24241890 Solenoid Assemby
    24236934 Solenoid Spacer Plate
    24238417 Speed Sensor
    24245720 Valve Body Plate
    Low & Reverse Clutch
    24224175 Backing Plate
    24232457 Center Support
    24224172 Clutch Piston
    24224732 Clutch Spring
    24235460 Friction Plate
    24224733 Retainer Ring
    24224737 Retaining Ring
    24232496 Steel Plate
    1-4 & 3-5 Reverse Clutch
    24224149 Clutch Backing Plate
    24222632 Clutch Backing Plate
    24226393 Clutch Bearing
    24237185 Clutch Housing
    24238700 Clutch Piston
    24238696 Clutch Piston
    24224708 Clutch Piston Seal
    24224707 Clutch Piston Spring
    24235681 Friction Plate
    24224147 Friction Plate
    24238698 Housing
    24240195 Retaining Ring
    24240201 Retaining Ring
    24237851 Seal Kit
    24232498 Steel Plate
    24238701 Steel Plate
    24239828 Waved Plate
    24239615 Waved Plate
    2 - 6 Clutch
    24224171 Backing Plate
    24240221 Friction Plate
    24232994 Retaining Ring
    24235463 Retaining Ring
    24224725 Spring
    24232497 Steel Plate
    24224659 Waved Plate
    4 - 6 Clutch & Turbine Shaft
    24240654 Clutch Backing Plate
    24237556 Clutch Housing
    24224714 Clutch Spring
    24224158 Friction Plate
    24237851 Retainer Plate
    24233406 Retainer Ring Selective
    24224648 Steel Plate
    24219390 Turbine Shaft O - Ring
    24224655 Turbine Shaft Seal Ring
    24224647 Waved Plate
    Cooler & Lines
    92191948 Hose, inlet
    92191949 Hose, outlet
    92190644 Pipe Assembly
    92218904 Pipe Assembly
    92191918 Transmission Oil Cooler (Radiator Assembly)
    Oil Pump & Converter Housing
    24236120 Converter Housing
    24237531 Torque Converter Seal
    24236939 Transmission Oil Pump
    Park Lock Linkage
    24234562 Manual Detent Lever
    24242085 Parking Pawl Actuator
    24225445 Shift Shaft Seal
    Part information contributor: HSV-GTS-300 (Paul)
