Results 11 to 20 of 26
Thread: Plastic fuel line connectors- how to remove?
    Central Florida
    Quote Originally Posted by hulkss View Post
    use KD 3321
    So is this.
    Central Florida
    That is the tool GM specified in the service manual.
    Plastic Collar Quick Connect Fitting Service
    Tools Required
    EN-46843
    Removal Procedure
    Caution: Refer to Gasoline/Gasoline Vapors Caution in the Preface section.
    Caution: Refer to Safety Glasses Caution in the Preface section.
    Relieve the fuel system pressure. Refer to Fuel Pressure Relief.
    Blow dirt out of the fitting using compressed air.
    Attachment 10104
    Install the quick connect tool over the quick connect fitting (1).
    Attachment 10105
    Pull the connection apart.
    Using a clean shop towel, wipe off the male pipe end
    Inspect both ends of the fitting for dirt and burrs.
    Clean or replace the components as required.
    Installation Procedure
    Caution: In order to reduce the risk of fire and personal injury, before connecting fuel pipe fittings, always apply a few drops of clean engine oil to the male pipe ends.
    During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated.
    This will ensure proper reconnection and prevent a possible fuel leak.
    Attachment 10106
    Apply a few drops of clean engine oil to the male pipe end.
    Attachment 10107
    Push both sides (1 & 2) of the quick-connect fitting together to cause the retaining tabs/fingers to snap into place.
    Attachment 10104
    Pull on both sides of the quick-connect fitting (1) to make sure the connection is secure.
    Inspect for leaks using the following procedure:
    4.1. Turn the ignition ON, with the engine OFF for 2 seconds.
    4.2. Turn the ignition OFF, for 10 seconds.
    4.3. Turn the ignition ON, with the engine OFF for 2 seconds.
    4.4. Turn the ignition OFF.
    4.5. Inspect for leaks.
    Yea, only issue being that the tool doesn't seem to fit :/
    SoCAL
    Haha! Your tool is too big
    Sent from my amazing and awesome iPhone4
    **RIP Shaun Finley**
    FUCK CANCER
    **RIP Charlie**
    '16 2SS NFG Camaro M6 NPP Mag
    Senior Member hulkss's Avatar
    Chaska, MN
    So is this.
    When I removed my GT intake manifold the KD tool worked.
    VE Commodore Sedan SS V-Series Special Edition, Left Hand Drive, PBM, Hacked Atari Gauges
    Power: 2014 Chevy Performance LS3 Crate Motor; Patrick G Tune, VCM Intake, Vector HSRK; Solo High Flow Cats, Solo Mid-Pipes
    Appearance: Vortekz Generators; RedlineGoods Shifter Boot; Holden Badges; GXP Diffuser; Stub antenna
    Handling: BMR Sub Frame Bushings, CTS-V Wheels, 255/40 & 285/35 Bridgestone S-04 Tires, GXP Rear Stabilizer Bar
    Brakes Centric Premium Rotors, ACDelco Ceramic Pads
    Central Florida
    As it will on that end. I'm at the tank end, different fittings. In any case, I got them off.
    Sep 2018
    Suburban Washington DC
    Which one worked, the red or blue? Or did you use something else?
    Beyond Help tchr49's Avatar
    michigan
    Don’t buy the cheap ones from Advance, they’re crap
    How the frick do you get the fuel line off to take the pump out? There is not enough room to get a fuel line disconnect tool in there.
  9. #19
    Push, squeeze the tabs and pull. You may need to twist.
  10. #20
    I tried everything I could think of with the tabs. Broke them off after trying to pull at them with picks. Tried using the picks from underneath, like a normal disconnect tool would work if there was room for it, and broke the nipple off the effin bucket. Too bad I only ordered the level sensor beforehand. Looks like I'm waiting till Tuesday for a whole new sender/pump unit.
