A/T - DEXRON®-VI Fluid Information
Bulletin No.: 04-07-30-037D
Date: November 21, 2007
INFORMATION
Subject:
Release of DEXRON®-VI Automatic Transmission Fluid (ATF)
Models
Attention: DEXRON®-VI Automatic Transmission Fluid (ATF) is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON®-III and/or prior DEXRON® transmission fluids.
Supercede:
This bulletin is being revised to update model/model year information. Please discard Corporate Bulletin Number 04-07-30-037C (Section 07 - Transmission/Transaxle).
MANUAL TRANSMISSIONS/TRANSFER CASES and POWER STEERING
The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRON®-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid. Power Steering Systems should now use P/N 9985010 labeled Power Steering Fluid.
Consult the Owner's Manual or Service Information (SI) for fluid recommendations.
Some of our customers and/or General Motors dealerships/Saturn Retailers may have some concerns with DEXRON®-VI and DEXRON®-III Automatic Transmission Fluid (ATF) and transmission warranty claims. DEXRON®-VI is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON®-III and/or prior DEXRON® transmission fluids. Please remember that the clean oil reservoirs of the J 45096 - Flushing and Flow Tester machine should be purged of DEXRON®-III and filled with DEXRON®-VI for testing, flushing or filling General Motors transmissions/transaxles.
DEXRON®-VI can be used in any proportion in past model vehicles equipped with an automatic transmission/transaxle in place of DEXRON®-III (i.e. topping off the fluid in the event of a repair or fluid change). DEXRON®-VI is also compatible with any former version of DEXRON® for use in automatic transmissions/transaxles.
DEXRON®-VI ATF
General Motors Powertrain has upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
Current and prior automatic transmission models that had used DEXRON®-III must now only use DEXRON®-VI.
All 2006 and future model transmissions that use DEXRON®-VI are to be serviced ONLY with DEXRON®-VI fluid.
DEXRON®-VI is an improvement over DEXRON®-III in the areas shown.
2006-2008 Transmission Fill and Cooler Flushing
Some new applications of the 6L80 six speed transmission will require the use of the J 45096 - Flushing and Flow Tester to accomplish transmission fluid fill. It is highly recommended that the clean oil reservoir of the machine be purged of DEXRON®-III and filled with DEXRON®-VI.
Information supplied courtesy of Alldatapro.com
