Results 1 to 10 of 18
Thread: Error code help
    Member Imdubious's Avatar
    Sep 2010
    Broussard LA
    Default Error code help
    Before I take it in for warranty. Thought I would ask you guys. Have 5 codes 4 are for the heater banks on each o2 sensor the other is for the Vapor resurculation solenoid checked the fuse as it is common to all the compontents and looked at all the wiring on the o2 sensors
    Silver/onyx GXP MG Tint, Vararam,Kooks 1-7/8"mids, Corsa Catback
    405 rwhp and 398tq w/o tune
    Sounds like youve got the standard codes for headers (need to get a tune!)... and check that vapor solenoid, you may have to move/unhook it when installing headers and the tubes aren't seated correctly.
    Sep 2010
    Broussard LA
    It did it before the headers where on and I had the exhaust and vararam on for two weeks before it did it
    Post the exact code numbers.
    Sep 2010
    Broussard LA
    P0030
    p0050
    p0135
    p0155
    p0443
    p0030 02 Sensor Heater Sensor Malfunction (Bank 1 Sensor 1)
    p0050 02 Sensor Heater Sensor Malfunction (Bank 2 Sensor 1)
    p0135 02 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1)
    p0155 02 Sensor Heater Circuit Range/Performance (Bank 2 Sensor 1)
    p0443 Evaporative Emission Control System Purge Solenoid Circuit Malfunction.
    Sep 2010
    Broussard LA
    Is that just the u2 senor saying there out of range? It threw the code at wot when it stumbled a bit.
    Yes the GM tech info says both banks oxygen sensor 1 & EVAP are on the same EMISSIONS1 circuit.
    There's nothing else on that circuit.
    Fuse for Emissions1 is F33 rated at 15A.
    It probably wouldn't hurt to check F32 as well , as although this is listed as EMISSIONS2 and supposedly for both banks oxygen sensor 2's, GM have been known to confuddle the naming conventions on oxygen sensors.
    DTC P0030
    DTC P0050
    DTC P0135
    DTC P0155
    DTC P0443
    Sep 2010
    Broussard LA
    Found it thanks for the help code is gone now!
