Silver/onyx GXP MG Tint, Vararam,Kooks 1-7/8"mids, Corsa Catback
405 rwhp and 398tq w/o tune
I unplugged the rear u2 sensor as that was the only thing I touched before the fuse popped the first time
I'm thinking it is the evaporate purge solenoid. It pops the fuse the second time you turn the car on after changing the fuse. I do get a hint of fuel smell when I start the car. Does any one have any ideas on this?
Formerly HSV-GTS-300
Hopefully it's the EVAP valve because those are cheap.
12606684
VALVE EVAP EMIS CNSTR PURGE SOL E (LS3, L76, BSI) 2009
$22-$30ish prices found online
Unplug the Purge valve, then change the fuse and see if it blows again. If not, there you go. If it blows again, do the same for the O2s until you find the offending circuit. If it still blows with all of the components unplugged, you may have a pinched wire causing a hot short.
Imdubious
Before I take it in for warranty. Thought I would ask you guys. Have 5 codes 4 are for the heater banks on each
oxygen sensor the other is for the Vapor resurculation solenoid checked the fuse as it is common to all the compontents and looked at all the wiring on the oxygen sensors
Thanks for the input guys. Replaced the oxygen sensor this weekend and drove the vehicle several times. So apparently that took care of it.
The most difficult part of the replacement is trying to get your hands up and onto the connector....the assembly line kinda builds around things sometimes...and this was one of them...laying on the garage floor underneath with a driveshaft in your way kinda hinders things....BUT it can be done.
After my check engine light came on, I tried reading the error codes with a cheap Harbor Freight Autel code reader. The "codes" were $7EA and $7E8, which are not in the correct format. Google turned up similar "codes" for a variety of GM cars. Someone claimed it was associated with a bad cat. My G8 has 4689 miles and has spent an abnormal amount of time idling in the driveway. I use premium non-ethanol gas. Any ideas?
2009 G8 GT, premium, sport, sport red metallic
Roto-Fab CAI
MagnaFlow 16887 Street Series cat-back
Superchips Cortex: RotoFab 91 Octane, 25% TM, AFM off
and splash guards (that look better than dirt)
Moderator, Retired
Start a new post instead of bumping a 5 year old post. Get the code read with a proper code reader.
RichsGreyGT
I finally took my G8 for a half hour drive, and check engine light went away. I suspect the oxygen sensors got dirty during the long idling sessions.
Roto-Fab CAI
