I'm looking for a set of Drag radials that will fit the 18" stock rims. The stock tire is 26.6" in diameter. I found that the BFGs are 25.4" and the MTs are 25.8".
How far off can the diameter be w/o hurting anything ??
11.350 @ 118.66 / 1.57 60ft [300 DA]
RPM tune, PatG cam, FAST 102, L92 heads ported by Greg Good, Kooks 1 7/8 headers,
RotoFab 102mm CAI, LS3 maf, UDP, JBA wires, Meziere water pump, SJM linelock,
Circle D 3600, 3.27 diff with Truetrac, GForce HD axles, Pedders bushings, Spohn trailing arms,
Camaro rims on the street & CCWs at the track....... SOLD
Looking for a 00-02 Camaro SS with A4
The different diameters might set off the ABS light, but at .4" taller on one end I doubt you would have any problems.
3780R- P245/40R18- 26X9.50R18- 25- R2- (8.0-9.5) 8.5- 9.6- 8.5- 25.8- 81
Fits 8 to 9.5 inch rims.
3782R- P265/40R18- 27X10.50R18- 28- R2- (9.0-10.0) 9.5- 10.6- 9.6- 26.5- 83
Fits 9-10inch rims.
http://www.mickeythompsontires.com/s...StreetRadialII
Stock G8 rims are 8", FYI.
Plastic Cuttin' Bad Ass!
THanks...those were the MTs I was looking at. I just wanted to know if the diameter difference would effect anything other than my speedo being incorrect at the track.
Stock diameter is 26.6 vs MT diameter of 25.8.
I run the 265/40R18 MTs on mine ,no problems . Running a smaller than stock dia. tire caused my car to slow down after 3 runs . I don't know why this happened but it did on two different occasions.
VMS ecm-tcm ,hrsk, GRRRR8 mods, Fonse perf. mods, Kooks LTH , Magnaflow muff., MT DRs, Dyno'ed 363rwhp@371tq 12.66@110.89 1.94 60'
97-99 corvette 18x9 rear rims
