im in fl so emissions dont matter im just trying to figure out which one of there systems work on LT with no mod.
Any of the mach systems will bolt up to doug thorley LT's with no cats.
will the DT shorty headers bolt up to the solo catback?
2009 Pontiac G8 GT Panther metallic black, Onyx/Red interior.
Roto-Fab intake, Doug Thorley shorty headers, catless, Solo mach exhaust, GXP front bumper, GXP rear diffuser, Roto-Fab Rad cover, Billet Prototypes oil catch can, GTPprix hacked atari gauge, Powerbond UDP and Camaro deep trans pan, AeroForce Interceptor gauge with cubby pod, GXP FE3 Struts/Shocks, GXP Transmission AUX Cooler and Jannetty Racing Transmission Dipstick.
2009 G8 GT was paid off on June 6th 2014
You don't have to modify any catback systems to work with the DT's. The DT's attach to the same point the stock cats do but they eliminate the cats. The DT shorty's will bolt directly up to either the Solo Cats or the stock cats. In my humble opinion the shorty's aren't worth it unless you replace the very restrictive stock cats. Replacing the stock cats with high flow cats and keeping the stock manifolds will net you better gains that replacing the stock manifolds and keeping the stock cats. I hope this isn't too confusing.
Gotcha, I didn't read that. In that case the Solo cats will work perfectly with the DT Shorty's. I asked Jeff@Solo before ordering the Kooks if they had done a DT LT setup and he said no. I would not think it would be a difficult modification though. The flange would be simple and you would probably have to change the rear 02 location. Solo would more than likely do this for free if someone were to drive to their shop or they would do it at a great price point. It would be nice to have them do this so they can possibly design a DT midpipe. The DT's are certainly a popular choice.
Yeah, just pointing it out.
If it were me, I would get the long tubes and work around those. You won't see much of a gain just doing shorties and a catback.
