Results 21 to 30 of 39
Thread: OEM GXP Transmission cooler kit for the GT
  1. #21
    Boardman, Ohio
    If purchased from my new site the price is actually cheaper
  2. #22
    Friendswood, TX
    Quote Originally Posted by Greg@PacePerformance.com View Post
    Cool!!!
  3. #23
    Addicted Member Sephiroth's Avatar
    Dec 2010
    Suffolk, VA
    Has anyone gotten beef from their dealer with this installed? A laughable idea for sure, but just wondering.
  4. #24
    Boardman, Ohio
    I doubt the dealer would even know it wasn't put on at the factory.
  5. #25
    Oct 2009
    Illinois
    Quote Originally Posted by bradshow View Post
    Looking at this in the pictures and not seeing it for myself, I have 2 questions.
    1. It looks as if this will still work with a Vararam, would you concur?
    2. Would it be possible to somehow incorporate a temp sensor on the hot side somehow? I'm adding a tranny temp guage and want to know where the best place to put it. I really don't want to drill and tap the tranny pan.
    Brad, Are you sure this would work with the Vararam? It looks to me like it might block air flow on one side.
  6. #26
    Oct 2009
    Webster, NY
    will this fit with the New Era OTR CAI?
    2008 NA G8 GT
    1/4 mile = 10.93 @ 123
    60' = 1.47
    DA = 500
  7. #27
    Boardman, Ohio
    I don't think it would have any effect on a OTR intake because it all mount in front of the radiator.
  8. #28
    Oct 2009
    Webster, NY
    Thanks
    2008 NA G8 GT
    60' = 1.47
    DA = 500
  9. #29
    Oct 2009
    Webster, NY
    Would this do a better job then the PCMforeless cooler for 170.00??
    2008 NA G8 GT
    60' = 1.47
    DA = 500
  10. #30
    Boardman, Ohio
    Sorry I don't know. It all depends on the size and design of the coolers.
    Maybe PCM for less has done some testing but I don't know for sure sorry.
