Results 11 to 20 of 39
Thread: OEM GXP Transmission cooler kit for the GT
    Nov 2008
    Charleston, SC
    Who has installed this, is it necessary to remove the nose of the car?
    2009 Maverick Silver G8 Gt
    VaraRam, Fasterproms Ported LSXR 102 & Ported Throttle Body, Comp Cams Trunions, UPR Catch Can, Holden Radiator Cover, BMR Sway Bars, BMR SFC's, BMR Tunnel Brace, BMR LCA's, CTS-V Wheels, GXP Brake Kit, Pedders Lowered Springs and Dampeners, GXP Rear Diffuser, Hacked Atari Gauges, Sliding Leather Armrest, Spencers 5000K Lows/fogs, GRRRR8 Heater Hose Relocation, EFILive V2, 35% Window Tint
    To install: BMR complete bushing kit, BMR Toe rods
    Boardman, Ohio
    I haven't actually installed one but I am pretty sure you have to pull the fascia to do the install.
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    does this work with people with a tvs since they have a heat exchanger in that spot?
    Boardman, Ohio
    It would work if you get the spacers from Magnacharger for the GXP. You can see them in the install .PDF for the GXP on their site.
    Friendswood, TX
    Quote Originally Posted by Darkmanx View Post
    Supremely excellent question Darkmanx!!!! Will this cooler work with the heat exchanger in place?
    Friendswood, TX
    Quote Originally Posted by Greg@PacePerformance.com View Post
    I just pulled down the .pdf from Magnacharger.......Not certain I'm seeing "spacers" on the document
    Friendswood, TX
    Lastly, what is the part number for this cooler? Apparently, Greg is no longer with Pace Performance!
    Boardman, Ohio
    No I am not with Pace directly but still can sell the parts
    New site on the way.
    The spacers are shown on page 23 in the GXP install manual
    Listed on my site now. WAS10385350
    Don't mind the look of the site. Waiting on my designer to get back with me.
  9. #19
    Southern NJ
    Greg. Good luck with everything!!! Still awesome pricing too!
    R.I.P. Charlie
  10. #20
    Friendswood, TX
    Should buy this in 2 weeks! Pricing will remain same?
