What other sizes will work with the stock 19" rims without causing problems?
255/40-19's?
Sorry if this is a repeat question
255/40-19's?
Do they make a 255/35-19?
That would keep the outside diameter about the same as stock.
I chunked my stock 19s at the last track day pretty bad. I'm going to replace with Kumho MXs in a 245/35-19 size. I've run the MXs as street tires and they wear very well. They are also very grippy, and are almost competitive with competition tires.
And, they cost less than $200 per corner, instead of $300 like most others. And, yes, their quality is just as good or better.
According to this
http://www.miata.net/garage/tirecalc.html
265/35-19's 1.5% too fast
265/40-19's 2.4% too slow
255/40-19's 1.2% too slow
255/35-19's 2.6% too fast
275/35-19's 0.5% too fast
Ok that's cool but I have another question -
How do you know what size width-wise will still fit on a certain rim?
I'm sure you couldn't just go from a 245 to either a 205 or 315 or something like that so is there a set formula to determine the min/max width of a tire on a rim?
-= R.I.P Charlie =-2008 Panther Black G8 GT 888 Edition #470
http://g8gt.blogspot.com
