Results 1 to 10 of 15
Thread: catch can help
    Senior Member hazer396's Avatar
    Sep 2009
    Chi-Town
    Default catch can help
    can someone tell me where to find the PCV Valve to install my catch can too?
    "Oreo" G8 V6 to LSA
    Another stock mustang wnt2gofst's Avatar
    Sep 2009
    Columbus, GA
    One side is drivers side back of valve cover. Other is behind the TB on intake. Follow teh tube that is connected to the rear of valve cover around.
    2014 Harley Davidson Street Bob-Vance and Hines Short Shot staggered.
    2013 F150 Ecoboost- Loaded and stock.
    WNY
    2009 SBM G8GT (Garage Queen)
    I check the site it looks like most products if not all are for the GT and GXP.
    Old Retiree in a Infiniti
    Current Car - Infiniti M37S
    Here's how the PCV system works on the V6 engine.
    Flow direction is shown with Arrows.
    Green is Fresh air Supply.
    Red is Stale Oily air.
    Fresh filtered Air comes from the Air Intake Pipe, thru the small FRESH AIR TUBE on the left hand side of the car.
    The FRESH AIR TUBE (shown in green) delivers the fresh air into the Rear of the Left Cam Cover.
    You do not touch or modify the FRESH AIR TUBE or touch the left rear cam cover fitting in order to fit a catch can to the V6.
    Stale Oily Air comes out of the Fixed 3mm Orifice at the Rear of the Right Cam Cover.
    The Stale Oily Air then enters (vertical red arrow) an arrangement of tubes which eventually branch out in a Y shape.
    The Y shape hose ends connect to the nipples on each side of the intake manifold.
    HOW TO CONNECT A CATCH CAN ON A V6
    a) Mount the Catch Can wherever it was designed to be bolted to the car
    b) Disconnect the PCV hose assembly inlet from the PCV Orifice Fitting (at the rear of the Right Cam Cover).
    c) Run a new hose from the Rear Right Cam Cover PCV Orifice Fitting to the INLET of the catch can. [Shown as Hose 1 in purple below]
    d) Run another new hose [Shown as Hose 2 in orange below] from the OUTLET of the Catch Can to the original PCV hose assembly inlet .
    Sep 2009
    Chi-Town
    thank you so much!!!
    "Oreo" G8 V6 to LSA
    Sugar Land Texas
    Paul is the man!
    Aug 2011
    Australia
    What do you do with the end of the right pcv hose that was connected originally?
    Quote Originally Posted by Matt_27 View Post
    See the revised drawing below.
    When totally stock 5 fits directly onto 4.
    ALL you disconnect is the stock Y hose at position 5 from the PCV orifice at position 4.
    You then run New Hose 1 from 4 to the new catch can.
    From the new catch can you run New Hose 2 to position 5.....entry point into the stock Y hose.
