Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: How do you access "Engineering Mode" on the driver display???
    Default How do you access "Engineering Mode" on the driver display???
    Newbie here, coming from an 04 GTO, and my new G8 has stuff for me to learn.
    Central Florida
    Start the car while holding the left button on the wheel.
    Central Ohio
    Hold down the left side scroll wheel on the steering wheel and turn on the power to the car while holding the wheel down.
    Vendors
    I push a button on my workbench.............
    VIP Member 08G8V8's Avatar
    Savannah, GA
    I took a road trip this weekend, so I went to Engineering mode to monitor the active fuel management and throttle postion. I hit the button on the wheel that normally scrolls through the DIC, and it kicked me back into the regular DIC. I don't understand why they have it programmed to allow you to go from Engineering mode to DIC mode, but not the other way around without turning the car off and starting it with the scroll wheel depressed.
    They should have either made it able to go either way, or just stay within the mode it is currently in until the car is restarted.
    Beyond Help jbradsh1's Avatar
    Smile
    Quote Originally Posted by jdsnov73 View Post
    Cause the guys that rigged up this sytem don't understand the word intuitive?
    Got it, thanx all.
    Central Florida
    Since I got my dashhawk I pretty much never use engineering mode. The only time I really need it is to check oil life.
    I still need to hook my dash hawk up and see it work...
    I made this sticky and moved it to electronics. This is a good question and one that should be readily available for answer.
    Thanks,
    Chris
    VIP Member Kermit's Avatar
    Va. Beach, VA
    What does this engineering mode do? I don't remember reading about this in the owners manual. Or maybe I'm just really out of it lately.
    2009 G8 GT MGM.
