FYI - The shop I used charged 1.25hrs labor for the swap. So if you don't want to get frusterated with the install and have an extra $100, just have a shop do it.
Thank CP, can't wait to test her our and see that the AC belt will still be on!
[COLOR="#000000"]
[B][COLOR="#000000"]
This is a little bit of a pain. I have done well until I get to the recessed bolt behind the compressor. Any tips for getting at this one? Thanks for any advice or tips.
219/223 .625 .625 112, 11.78 @ 119, 440/421, Crawford heads, tb, intake. Kooks 1 3/4 lts and solo Mach balance catted with added Solo resonators, VCM, 3.45's, stock stall.
I've only tossed my belt once with the stock bracket, but this is still a great deal from Paul. I checked my cost on the new bracket and it is more than Pauls shipped price.
Keep the great work and prices Paul!
Try this thread for tips.
ForumVendors-=Crazy Paul's Holden Parts=-NEW Improved Holden A/C Belt Throwing Fix.
http://forum.grrrr8.net/showthread.php?t=24830
There is a newer/different one that just came out in October ( I think it was October.)
I don't have access to it anymore, but it was directly related to an upgraded tensioner. Strangely enough, I believe the Caprice was also listed, Possibly in error. Don't recall whether it listed the Camaro or not...
Caprice would be in error. Although it's a WM and not a VE, Caprice built after November 2009 would have the upgrade installed.
"All VE V8's from 6G1EP4EH2AL419681 19/11/09 production on incorporate this fix."
You can search bulletins by date or keyword (G8, belt, bracket, 92244381,92244378,92252927)
here or here:
http://sandyblogs.com/techlink/
http://www.archivedsites.com/techlink/
October 2012 : http://sandyblogs.com/techlink/wp-co...ink-2012-F.pdf
My G8 GT is in the shop right now because of throwing the A/C belt, which came off I suspect because of the harmonic balancer wobbling. I had to get my car towed because once I turned it off after the problem occurred and then tried to start it again, the car system diagnostics went through every alarm it could and left me with a big red X and a "Contact Dealer" message. The car entered a security lockout and wouldn't even give me my key back.
I can't wait to hear their diagnostic and the subsequent estimate... I really hope this is part of the 100k mile powertrain warranty.
