Results 21 to 30 of 47
Thread: HSRK Install
  1. #21
    Sugar Land Texas
    Quote Originally Posted by G8GTlawride View Post
    So thats what that means!
    LMAO!!!!! George is notorious now!
  2. #22
    Central Florida
    If you use a utility knife, you too can be a "plastic cuttin' badass!".
    Do yourself a favor, use a dremel or something. I still can't imagine how George did that with a knife....
  3. #23
    Clarks Summit, Pa.
    Brand new blade.
    I must have gotten the "thin" plastic.
    Plastic Cuttin' Bad Ass!
  4. #24
    Senior Member Featherburner's Avatar
    NJ
    Brand new blade.
    Rare factory "light weight"
    John
    2009 Stryker Blue Metalic GT Bolt-on G8 Record holder: 11.828 @ 114.61 with a 1.603 60'
    1993 Pontiac Formula FIREHAWK 385ci., M6, Strange S60.
    1968 Firebird Formula Convertible *Restomod project*
  5. #25
    So with the HSRK, I assume this really only has effects in warmer temps/lots of passes down a track? Under normal driving conditions: IE: cooler weather on the highway, it doesn't really help much, no?
  6. #26
    Sugar Land Texas
    By the sensor reacting at a much faster rate, the ecm does not pull timing as much. Tuesday it will be 59 degrees and I will bet that I can pull low 50s on IATs at 100mph and I know it wont do that with an insolated MAF.
  7. #27
    I used a grape/linoleum knife. Couple stokes to score it then cuts through like butter if sharpened properly. I use those knifes every day though so they are like an extension of my hand.
  8. #28
    Central Florida
    Quote Originally Posted by JMorris View Post
    Hmmmm.... I believe we have another plastic cutting bad ass among us.
  9. #29
    VIP Member Blackdevil77's Avatar
    Long Island, New York
    The factory intake air temp sensor is located in the Mass Air Flow meter. Its location makes it prone to heat soak which causes false readings and a loss of power. By installing this kit, the sensor has a faster response rate and allows the ECM to see the true temp and timing loss is all but eliminated. This is the correct location for Roto-Fab. The sensor should be mounted as close to the filter or in filter neck on most air intake systems. Approx. time .5 hrs. Necessary tools: Cordless Drill and stepper drill bit. A grommet is required for install unless mounting in filter neck. GM Part # 24504388.
    Awsome tutorial. Definitely gonna use this but one quick question. Were exactly is the MAF and how do you connect this to it?
  10. #30
    Sugar Land Texas
    That piece with the arrow is the MAF. You unplug the MAF, then plug the harness in between it.
