Results 1 to 10 of 11
Thread: Driveshaft - Info & Repair Instructions
    Default Driveshaft - Info & Repair Instructions
    Here's a better idea of the fasteners involved. Although each coupling has 6 bolts going thru it, there are 3x yoke to coupling bolts and 3 x coupling to tailshaft bolts. They are different bolts with different torque requirements.
    Front section
    Rear section
    (Item 1) Tailshaft assembly including 2x couplings and total 6 coupling bolts & 6 coupling nuts, but not including coupling to trans or coupling to diff fasteners. Part No 92157731
    (Item 6) Coupling Kit including 1x coupling and total 3 coupling bolts & 3 coupling nuts. Part No 92149040
    Capitol City G8 G8V8's Avatar
    Jacksonville, FL
    Thanks for pulling this all together Paul. Great to have it all in one place. As some of these pieces of hardware are single use, knowing what to buy comes in real handy! Know what socket is needed for #2?
    HSV E3 Bumper and Fenders
    VMS DoD-Delete with heads
    TVS1900
    RCR TB
    Kooks 1 7/8 Mids+SOLO Mach
    ZL1 Brakes
    Roto-Fab
    Banned for not playing nice
    Northern Virginia
    Thanks! Hopefully be crawling under there again soon if someone would come out with a driveshaft!
    SOCKET SIZES REQUIRED.
    Item 15 nut = 19mm
    Item 2 bolt = 14mm . Edit --> Torx External socket E-18 fits better.
    Item 5 nut = 19mm
    Item 5 bolt = 18mm
    Item 4 bolt = 13mm
    Item 3 bolt = 18mm
    Clarks Summit, Pa.
    That one, I believe #2, is an external Torx style.
    http://en.wikipedia.org/wiki/Torx
    An external TORX version exists, where the screw head has the shape of a TORX screwdriver bit, and a special TORX socket is used to drive it, although a standard hex socket can often be used. These are found primarily on automobile engines.
    Plastic Cuttin' Bad Ass!
    Yes.
    http://www.wihatools.com/Marketing/torxspec.htm
    Northern Virginia
    Yepp, I had to get a set of those when I replaced my Benz diff.
    Pictorial Summary:
