Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: GRRRR8 Acronyms explained/detailed as well as abbreviations.
    Exclamation GRRRR8 Acronyms explained/detailed as well as abbreviations.
    Ok guys and gals, When I first started coming to the G8 forums I was completely lost for a while because I had NO idea what half of the stuff you guys were talking about was. I have been into bikes for the last 10 years so I slowly learned it all after putting two and two together and sometimes coming out with 3.
    So the reason for this thread is to explain all the acronyms that we associate with cars. Please add the ones you can think of and I will put them on this list. (oh and I found most of these on the net) lol This list is to be used as a KEY for those looking for a meaning. CAI kicked my butt for a while but I ended up figuring it out on my own. Many people don't want to look stupid (me included) so here's a list.
    Common GRRRR8 acronyms:
    ECM = engine control module
    TCM = transmission control module
    BCM = body control module
    PCM = powertrain control module
    HSRK = Heat Soak Reduction Kit
    CAI = Cold Air Intake
    LP Mod = Charlies Lower Panel Mod
    Generics!
    4WD/AWD = 4 Wheel Drive, All Wheel Drive
    ABS = Anti-Lock Braking System
    AFC = Air Fuel Controller
    AFM = Active Fuel Management
    AS = Active Steer BHP = Brake Horsepower
    BOV = Blow Off Valve
    CATS = Computer Active Technology System
    CBV = Compressor Bypass Valve
    CDI = Compact Diesel Injection
    CC = cubic centimeters
    CE = Classic Edition
    CI = cubic inches
    CSL = Coupe Sport Lightweight
    CVT = Continuously Variable Transmission
    DA = Density Altitude
    DAC = Downhill Assist Control
    DBC = Dynamic Brake Control
    DE = Deluxe Edition
    DINO = Non synthetic oil short for dinosaur as it came out of the ground...
    DOD = Displacement on Demand (same as AFM)
    DOHC = Double/Dual Overhead CamShaft
    DP = Downpipe
    DSC = Dynamic Stability Control
    DSG = Direct Shift Gearbox
    DVC = Dynamic Vehicle Control
    EBA = Electronic Brake Assist
    EBD = Electronic Brake-force Distrubution
    ECT = Electronically Controlled Transmission
    ECU = Electronic/Engine Control Unit
    ESP = Electonic Stability Program
    ETCS-i = Electronic Throttle Control System w/intelligence
    FF = Front Engine, Front Wheel Drive
    FI = Forced Induction or Fuel Injected
    FIPK = Fuel Injection Performance Kit (K&N CAI)
    FMIC = Front Mount Intercooler
    FPR = Fuel Pressure Regulator
    FR = Front Engine, Rear Wheel Drive
    GT = Grand Touring, GT Series in Racing
    HAC = Hill-Start Assist Control
    I(as in I-4) = Inline Cylinders
    IVT = Infinitely Variable Transmission
    L = Limited
    LCV = Lightweight Concept Vehicle
    LE = Limited Edition
    LM = Le Mans
    LSD= Limited Slip Differential
    LTH = Long Tube Headers
    M = MotorSport
    MAF/MAS = Mass Airflow Sensor
    MR = Mid Engine, Rear Wheel Drive
    N/A = Naturally Aspirated
    NMU = Nitrous Management Unit
    PASM = Porsche Active Suspension Management
    PSM = Porsche Stability Management
    PTM = Porsche Traction Management
    R = Racing, Rally version
    R/T = Road/Track
    RAHC = Rear Adjustable Height Control
    RR = Rear Engine, Rear Wheel Drive
    RS = Rally Sport
    RWHP = Rear-Wheel Horsepower
    S/C = Supercharged
    SE = Special Edition
    SMG = Sequential Manual Gearbox
    SMIC = Side Mount Intercooler
    SOHC = Single Overhead Camshaft
    SRS = Supplemental Restraint Systems
    SSG = Sport Sequential Gearbox
    SUV = Sport Utility Vehicle
    T/C = Turbocharged
    TB = Throttle Body
    TCS = Traction Control System
    TDC = Top Dead Center
    BDC = Bottom Dead Center
    ATDC = After Top Dead Center
    BTDC = Before Top Dead Center
    TDI = Turbo Diesel Injection/ Trendline
    TDI* = Toyota Direct Ignition*
    THS = Toyota Hybrid System
    Torsen LSCD = Torsen Limited Slip Center Differential
    TM= Torque Management
    TQ = Torque
    TP = Testpipe
    V(as in V6) = V-Engine Type
    V(As in 16V) = Valve
    VCD = Viscous Coupling Differential
    VHPD = Very High Performance Derivative
    VIM = Vehicle In Motion
    VIN = Vehicle Identification Number
    VIP = Vehicle Intrusion Protection
    VSC = Vehicle Skid Control
    VTEC = Valve Timing Electronic Control
    VVT-i = Variable Valve Timing w/intelligence
    VVTL-i = Variable Valve Timing and Lift w/intelligence
    W(as in W16) = W-Engine Type
    WHP = Wheel Horsepower
    WOT = Wide Open Throttle
    WRC = World Rally Champ/Car
  2. Thanks aussie1378 thanked for this post
  3. #2
    Sugar Land Texas
    Now I need 1 for all the NON car related ones!
  4. #3
    Central Ohio
    VIM = Vehicle in Motion
  5. #4
    Namely computer ones right?
  6. #5
    Sugar Land Texas
    Correct. I know some on here would appreciate it too.
  7. #6
    Addicted Member JoeSyko's Avatar
    Wildomar, CA
    TYSMFPTT. IRNI
    (Thank You So Much For Posting This Thread. I Really Needed It)
    2008 Pontiac G8 GT / Premium Package / Stealth Blue Metallic
    SHOW: Tint / "Pontiac" & "GM" badge delete / "V8 6.0 Litre" Oz badges / Reflective Concepts Arrowhead Overlays / IWM w/ Blue Display
    & GO:Vararam OTR "Baby SuperCharger" / VMS ECM/TCM Tune + HSRK / Corsa Cat-Back
    2010 Dodge Challenger SRT8 / Special Edition / Plum Crazy Pearl Gone but not forgotten
    2013 Dodge Challenger SRT8 / Special Edition / Plum Crazy Pearl
  8. #7
    Lethbridge
    BCM = body contol module
    SIIHB = Stick It In Her Butt
    2009 G8 GT::Panther Black
  9. #8
    Sugar Land Texas
    The SIIHB is the one that works best in most applications.
  10. #9
    Lethbridge
    Just make sure you have proper lubrication.
  11. #10
    Lake Jackson, Tx
    Quote Originally Posted by jnak View Post
    See DINO
