I do occasionally hit the drag strip. I'm planning on doing the whole suspension with a mixture of poly, derlin and even some pieces with roto joints to reduce or eliminate unwanted movement. Thanks for clearing that up though!
so this may get some bashing but what would be an offset for wanting some wheels to make the car somewhat stanced or having a bit of poke.
I reviewed the main sticky and think this will work for a staggered set up but want those that have done it, real results, if this has posed no problems
Rims are
Front
19x8.5 Offset 45 , tire is 245/40/19
Rear
19x9.5 offset 45 , tire is 275/35/19
Both tires are approx 26.6 height same as my current 245/45/18's
I do not want to have tire rub so limiting the rear width. Car is on stock suspension
Again, the front sticky says this should pass
Tires I am thinking of are General Gmax AS03's
08 GT MGM Onyx/Red Premium
Winter 225/55/17
Summer 245/40/19
RotoFab
Maverick Man CF Spoiler
More offset for the rear will be needed
Winter 225/55/17
Summer 245/40/19
RotoFab
The lip on the fender is the issue. More positive offset moves the wheel further inboard. A +50 will be close, but should be fine on a 275mm wide tire.
For reference, on the Chevy SS (VF Commodore) the wheels are 19x8.5" +48et front and 19x9" +57et rear. Stock tires are 245/40/19 and 275/35/19.
Winter 225/55/17
Summer 245/40/19
RotoFab
Ok, decided against a staggered set up for various reasons, but got some eyes on a this
19x8.5 35 offset with 245/40/19 on all 4 corners
I know the offset is going to push this out 19 mm
Again stock ride height, per the first page sticky, this should work with no clearance issues, just want to be sure so when I get them, when installed, if they rub, my wife will pretty much give me the you are in trouble look
Thanks again
Winter 225/55/17
Summer 245/40/19
RotoFab
