Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Holden 2 piece Engine Covers $310 shipped
    Default Holden 2 piece Engine Covers $310 shipped
    http://members.iinet.net.au/~pjsadle...s/Page2925.htm
    Edit: July 18 2013.....Price drop from $310 to $275 shipped.
    Need to clear 3 sets from stock.
    These 2 piece Holden 6.0 Covers require the following in order to fit the Pontiac G8-GT :
    a) You need to trim the passenger side cover to clear the heater hoses....unless you have done the Heater Hose Relocation mod.
    b) You need to remove and discard the beauty/noise cover from on top of your LS3 intake manifold.
    c) You need to purchase 4x threaded studs #11609319.
    Greg@Pace sells these studs way cheaper than I can.
    http://paceperformance.com/index.asp
    These 2 piece covers are Holden OEM fitted on the VZ 2005-2006 6 litre cars.
    Those cars did not have the heater hoses in the same place as G8-GT and had the earlier L76 intake with no beauty cover. Hence the reason for the mods required.
    Link to Intake Cover Removal Mod:
    [2 piece covers will not clip onto your fuel rails unless you discard the intake cover]
    http://www.forum.grrrr8.net/showthread.php?t=146
    Link to Heater Hose Relocation Mod:
    http://forum.grrrr8.net/showthread.php?t=326
    or
    Trimming the Passenger Side Engine Cover to clear the stock heater hoses is necessary.
    Before Trimming (front)
    After Trimming (front). These are the trimming tools.
    This owner has also highlighted the logo using Duco touchup paint and a fine modelling brush.
    Before Trimming (rear)
    After Trimming (rear)
    You need 4 x these threaded studs:
    They screw in here, 2 into each valve cover, to firmly locate and support the bottom of each cover.
    The covers also clip onto your stock fuel rails at the top.
    If you ever lose or need to replace the rubber cups from underneath each valve cover (2 per side).
    # 24453627 INSULATOR GM LIST $6.89
    They're also used on 05 and 06 Pontiac GTO's
    Senior Member r1owner's Avatar
    STL
    Are these back in stock?
    Quote Originally Posted by r1owner View Post
    Unbelievably no.
    Holden apparently did a production run last Friday but these are yet to hit the shelves in Aust. I haven't been able to buy any since 14th Feb.
    5 sets that I sent by sea in mid Feb have only just arrived to fulfil existing paid up USA orders. There are none of these left now.
    I'll let you know here when I get my hands on more stock.
    Clear Lake, IA & Naples, FL
    I have a set I'll sell for $300. with posts!!!!!
    HA HA... Paul!
    Actually, mine are "in the mail!"
    NFS- But will post pix when I get them on!!!
    Confused, Dazed & Verklemp
    Addicted Member Darkside's Avatar
    Cleveland, OH
    Quote Originally Posted by Rob Moser View Post
    Not till Monday Rob.
    2009 Liquid Red G8Gt- Vector, Vararam, Stainless Works
    447 rwhp / 411 rwtq , Mustang Dyno
    Big thanks to that Crazy Paul guy!
    2013 SHO, Livernois tune, airraid, h&r springs, SW downpipes/catback
    2003 Saleen Mustang Vert'
    2006 Jeep Srt-8
    Just had to give Crazy Paul grief....
    He has really been helpful in so many ways on my G8!
    10 Star recommendation!
    Jul 2011
    Gilbert AZ
    what radiator cover is that??
    09.1 G8 GT, 20x9/10 Red G wheels, magnaflow catback, DT's, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP rear diffuser, BMR strut bushings/cradle inserts, BMR sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel.
    http://i92.photobucket.com/albums/l4...psce2f18b1.jpg
    Quote Originally Posted by djerickd View Post
    Probably a Holden radiator cover with some home made renovations added.
    The piece with the Caution sticker on it was added to better blend with the aftermarket long radius intake air coupling.
