2009 Liquid Red G8 GT, Stealth VMS ECM/TCM Tune, Vararam Ram Air, VMS HSRK, Front Panel Mod, axle-back straight pipes with capped Helmholtz chamber.
yeah its kind of weird mine didn't seem to get worse and was only noticeable as the weather got colder... its going in for new seals tomorrow...
Livernois Stage 1 cam, valve job, milled heads, ported intake, kooks mid length 1 7/8 headers, corsa cat back, rotofab CAI, Pedders XA Street Kit, BMR trailing arms.
427 RWHP / 397 RWTQ
Vertini Riviera 19 x 8.5 and 19 x 9.5. Bridgestone Pole Position 245/40/19 Fr and 275/35/19 Rr
I am going to mention this at my next oil change too, which should be later this week, maybe friday and see what they say.
Mine has not gotten any worse....only notice it like mentioned before, when the car is cold. It does it longer in the cold weather cause the car seems to stay colder longer.
[COLOR="#000000"]
[B][COLOR="#000000"]
I brought mine into the dealer today for something else and told them about this, we'll see what they do, i did mention the seals too.
[COLOR="#000000"]
If you have a 2-3 shift flare when you are at high throttle situations, and your TCM is properly updated, there is a good chance something is wrong with your trans, whether it be a seal or the clutches have a problem.
But, to the guys that say that they are feeling a little flare once in a while, a 50 rpm flare is normal to occur every 15-30 shifts (depending on application) randomly in different gears, this is how the TCM readapts real time as components break in/wear/etc. If this is what you are seeing then it is normal.
I'm having them check mine once my ball joints come in because mine jumped well beyond 50rpm (more like 200 or so).
2008 G8 GT #509 of 888 - Ignition Orange
Performance: NEP OTR Intake, NEP Custom ECM/TCM Tune, VMS HSRK, Solo J-pipe Axle-back and X-pipe
Appearance: 5000K HIDs, NEP Gauge Bezel, third_shift studios 888 Shifter Plaque, GXP Diffuser, 3.5" Exhaust Tips
332 RWHP / 349 RWTQ
Best 1/4 - 13.215 @ 105.17MPH, 60' - 2.01
www.fourdoormafia.com
Mine is in the 200-300 rpm range and it just started at 26k miles its not normal.
Mechanic and drivability guy drove it around the block and confirmed that it was not normal and it needed the seals clutch fluid seals replaced per the PIP.
It has never slipped at WOT that I could tell, but after owning the car for almost a year and a half and getting used to the crappy transmission I know when it is doing something it shouldn't LOL
427 RWHP / 397 RWTQ
