Results 21 to 30 of 40
Thread: No BS dyno test of Vararam CAI for G8
  1. #21
    Technical Advisor Patrick G's Avatar
    Victoria, Texas
    Quote Originally Posted by dandragonrage View Post
    Low LSA
    Not exactly. You can have huge overlap with a wide LSA cam and lots of duration. A 224/224 110LSA cam has 4 degrees of overlap at .050" while a 232/238 114LSA has 7 degrees of overlap. See how it works? Wider LSA, but still more overlap. You can't make a blanket statement about overlap and LSA. You have to include duration.
  2. #22
    MA
    Moderator GM_Fan's Avatar
    Indiana
    What kind of MPG are you getting and at what speed?
    I can eeek out 28-29mpg at 55mph on a long flat stretch. It quickly goes down when I get on the Interstate at 70mph. Then I'm lucky to see 22-23mpg. According to the DIC.
    I'm really interested to see what cam profile can still give good performance and still run on 4 cylinders while just cruising.
  4. #24
    MA
    What about for those people that go ~85 on the highway? Not that I'm implicating anyone here or anything....
  5. #25
    Indiana
    If you are going 85 you probably aren't worried about fuel mileage much.
    I was asking about 70mph because that's the upper speed limit for Interstate traffic in my state. Maybe I should ask about 65mph if that the national average of Interstate traffic.
    EDIT: I read more and did find out what I was looking for.
    Quote Originally Posted by Patrick G
    With my tuning tweaks, I can cruise in 4 cylinder mode at 75mph in the G8. I knocked down 26mpg on a trip to Texarkana last week. A solid 2 mpg better than the EPA highway rating. My around town mileage is 16 which is around what the Jeep would get on the highway, haha.
  6. #26
    Victoria, Texas
    I finally had a chance to log the MAP numbers of the stock airbox vs the Vararam on the dyno and at speed. Here are the findings:
    Stock Air box:
    kPa would drop from 101 to 96kPa at WOT on the dyno and at speeds of over 100mph. No ram air effect.
    Vararam:
    kPa would drop from 101 to 98kPA at WOT on the dyno. (2 kPa better than stock).
    kPa would hover between 99-100kPa at speeds above 60mph with an occasional 101kPA. (4-5 kPa better than stock).
    Net result, the Vararam gave 2 kPa less restriction on the chassis dyno vs. the stock air box and added an additional 2-3 kPa in pressure at speeds above 60 mph. Since we gained around 10rwhp on the dyno with a 2kPa gain, it is possible to pick up a total of 20rwhp over the stock airbox at speeds over 60mph considering the 4-5kPa gain of the VR vs. stock.
  7. #27
    Sugar Land Texas
    Thanks for the info Patrick.
  8. #28
    Addicted Member johnh's Avatar
    Michigan
    Great info Thanks.
    2009 G8 GT Stryker Blue Prem/Sport/Roof
    Go: Rotofab, Corsa Exhaust, Kooks Mids, a little HPT secret sauce = 13.1@108 (traction where are you?)
    Show: V8 Holden Badges, Clear Side Markers, GXP Rear Diffuser
    Misc: AutoDim Mirror, Almost Factory Bluetooth
    Previous Rides: 2004 GTP, 2004 GTO, 2002 TA (miss this one)
  9. #29
    Devil's Advocate Ktlplxm's Avatar
    Nov 2008
    Charlotte, NC
    Quote Originally Posted by GM_Fan View Post
    I have an Ed Curtis cam extremely similar to the New Era non DOD cam. In my car @ 70-75 mph I still can maintain 27mpg. It could potentially be higher, but I do have another full liter worth of engine to feed with fuel. I believe the cam is 228/240 with a .600/.600 on a 114.
    Winning may not be everything, but its still better than losing
    I don't know you. I don't know what have done. If you are looking to talk up a race for 3 hours, I can tell you I don't have the time. But what I do have are a very particular set of parts; parts I have acquired over a very long career. Parts that make me a nightmare for people like you. If you go home, that'll be the end of it. I will not look for you, I will not punk you. But if you don't, I will punk you, I will race you, and I will embarrass you.
  10. #30
    Beyond Help johnbell2's Avatar
    Austin, TX
    Quote Originally Posted by Patrick G View Post
    You have to include duration so that you know how long both the intake and exhaust valves are open at the same time (hence, overlap), correct? Maybe it's obvious but I'm new to all this...
