Results 1 to 2 of 2
Thread: CTS V coupe wheels. tireand lowering,milling pad / need advice before I pull trigger!
    May 2015
    Default CTS V charcoal satin coupe wheels Installed with 285/35-19 BFGoodrich
    I think they look better than I thought...glad I've decided to stick with them.
    I just need to drop it now.
    I also think the Silver brembo's in the front will look good behind the charcoal.
    They do rub In the rear if I hit a Very large hump / dip in the road going 65-70 but its only slightly.
    I will probably go with Teins as they only lower the rear .6" in the rear
    If anyone has run 10"X19" with 285/35 and has lowered have you gone with Eibachs, H&Rs or Teins?
    I'm guessing the 1" or so the eibachs or H&R would be pretty bad and I'd be safer going with the Teins or will a .4" drop even make a difference?
    Either way here is what it looks like so far.
    May 2015
    I had the fenders rolled almost flat just to be sure.
    Also the back pad has no room for milling as the cone seat is 1/4" from the back pad.
