Page 1 of 39 12311 ... LastLast
Results 1 to 10 of 382
Thread: Tweaking with HPTuners
    VIP Member PerfectD3's Avatar
    Valdosta, GA & Deland, Fl
    Default Tweaking with HPTuners
    To those that are experienced, please chime in with some pointers or feedback. Also, anyone know how to load the data bit up for logging our shift times? I'm posting up my tranny tweak file, stock file, and a log that I took during the tranny tweak road test (albeit it wasn't logging any tranny parameters).
    http://www.mediafire.com/?sharekey=f...4e75f6e8ebb871
    PS - Charlie, you think you can add the .hpt and .hpl for attachments?
    BTW - SOTP, I didn't feel a difference.
    Very stock... looking.
    3E5X1 US Air Force
    Deployed...errr...Vacationing at Eskan Village, KSA
    Haymarket, VA
    Quote Originally Posted by PerfectD3 View Post
    YES. We need this. I have been meaning to have them add this format for a while but I am lazy.
    2008 MGM G8 GT (795 of 888)
    MODS: HPTuner, Circle-D Stage I 3600 Stall Converter, Livernois Stage II non-DOD cam, ARH 1-3/4 LT's, Rotofab CAI, Powerbond 25% UDP, VMS HSRK, NGK TR-5IX, LC-1 WBO2, 18% tint
    Track: 12.090@114.88 1/4, 7.756@??? 1/8, 1.712 60'
    VIP Member norm8332's Avatar
    Near Buffalo, NY
    First, I'm not an expert in that I don't do this for a living.
    Try disabling power downshift TQ management. It takes the lag out. It's not hard on it at your power level.
    You could raise the shift pressures by about 20% IMO. Also you only adjusted the normal desired shift times, I'd do special and downshift too.
    Good luck.
    PS: I'd like to see attachment support too, as long as tunes aren't posted that were paid for.
    My Garage
    Administrator Steve's Avatar
    Olympia,WA
    Quote Originally Posted by g8_795 View Post
    Done
    -= R.I.P Charlie =-
    http://g8gt.blogspot.com
    3E5X1 US Air Force
    Steve - How big can we upload as well? I want to say the standard .hpt file size for our car is 3.3Mb and the max .hpl that I have seen is 1.7Mb. Since I have seen very few people here even discuss HPT tweaks, I don't think it'll kill your server.
    3E5X1 US Air Force
    VIP Member boomer's Avatar
    Peoria, AZ
    Testing, looks like it works
    Attached Files Attached Files
    Photos
    320 rwhp/340 ft-lb
    1/4 mile: 13.30 @ 105 mph
    Hey Boomer, I see your posts all over HPT forums in regards to the G8. Do you have any input as far as my tranny settings? I'm waiting for my WB bung to be welded in so the ECM is off.
    3E5X1 US Air Force
    w00t! Got my WB bung welded in after work and the guy even fixed the rear hangers on my ARHs for me for free!
    3E5X1 US Air Force
    Feb 2009
    Hope Mills, NC
    Default G8 HPT File
    Here is a copy of my G8 HPT file. Would say it is anything special but the trans works great. Changed all the shift points and properties. Worked very well on a second G8 I loaded it on. If you drop the shift times to .15, it will rip into 3rd also. Wouldn't change any of the pressure as I haven't seen a need. You can change the shift speeds enough to make it violent.
