Results 1 to 7 of 7
Thread: Gap on front nose fix....
    Senior Member Superdave's Avatar
    Feb 2009
    Baton Rouge, LA
    Default Gap on front nose fix....
    David T.
    2009 Pontiac G8 GT, 6.0L A6
    Best ET 13.04 @ 108mph, 1.94 on Stock 19's
    Mods: Vararam, EPS Tuning, HSRK, X-Pipe Mod,
    BMR F&R Sways, 3.5" Dual SS Tips, Frnt V Calipers,
    DBA Rotors, Stoptech Pads, GXP Diffuser, V8-6Litre
    Badges, Holden V6 Radiator Panel, DDM 35w-5K
    HID's, Matte Black 19x9.5"Avant Garde M310's
    with 275/35's.
    Senior Member SinCity G8's Avatar
    Las Vegas
    Nice fix I will have to try this
    09 SBM GT, Custom cam, AFE intake, Kooks 1 7/8" LTs, Kooks full exhaust, Yank 3200, BC coilovers, BMR sway bars, adjustable end links, sub frames, and trailing arms, Tuned with HP Tuners by LEP, HSW brute force kit, Forgeline DE3P wheels. 422hp/390TQ N/A, Still need to tune for the spray and see what it makes.
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    Makes sense. I have lowered my bump stops and it did not help. My pass side sits about 3/16 higher than the drivers so I will try a larger spacer on that side.
    VIP Member norm8332's Avatar
    Near Buffalo, NY
    My Garage
    VIP Member conipc's Avatar
    Texas Hill Country
    Default what I used...
    I used plastic spacers, from Lowes, as well as longer bolts and a fender washer under the bolt head. I re-used the pushpins, but didn't seat them all the way. Cut the gap by about 2/3....
    '09 SRM GT. Pedders/BMR bushings, Whiteline front swaybar, BMR rear sway bar, trailing arms, subframe connectors, Spohn rear LCA, GXP rear shocks, GTS wheel, Vector HSRK, Ls2Portworks throttle body, Vararam, GXP front Brembos, EBC pads, Russell brake lines, XXR wheels, Corsa catback with custom tips, hacked Atari gauges, V6 taillights/door handles, upgraded speakers, black window trim, blacked grilles, custom pin stripes,
    Dec 2010
    Jacksonville, FL
    i removed the push pins...re used the same bolts, and put approx 6 washers from advance auto parts that would fit around the current bolts.....im kinda against rigging as such...but it closed the gap enough for people to stop asking me what body shop i took my car to....ugh.. horrible design.
    Senior Member BLKG8's Avatar
    I actually placed something under the bumper nose that lifted it up to where I should be. And loosened and tightened the top bolts to abjust the nose lift. No strain on the plastic where the bolts would hold the weight of the nose....Nose gap no more. Did it about a year and half ago. Actually had forgotten about it.
    ________________ _
    '08 G8... Panther Black
    Premium & Sport Pkg.- 7/08
