I am stumped on this one. My wife came home complaining that the headlights shut off on her while driving home the other nite. I pulled the fuse for the Right Headlight, examined it, and put it back in. Right headlight came on. Pulled the left, and examined it, same thing. Light came on. Figured it was corrosion on the Fuse terminals - problem fixed right?
Two days later both lights are out again. Pulled the fuses and Nada. Doesn't work. Fuses look intact. Replaced the fuses with new ones, but again no dice. Shortly after I realize that the DRL's are working but as soon as you rotate to the low beams they quit. I looked at the wiring harness for the low beams, but couldn't see any signs of damage to the wiring grommet, or any signs of corrosion. I pulled what I believe is the DRL relay out of the harness that is mounted to the frame rail in front of the radiator, examined it and plugged it back in. No dice.
The turn signal stock doesn't appear to be loose. I rotated the switch and tried to hold it in between parking at low beams to see if it was a flaky switch, but that did nothing.
What else can I check? I am at a loss. Highbeams work fine. Parking lights work fine, DRL's work, but no low beams. Funny thing about it, they did work after pulling the fuses and putting them back in, but not no more now.
Any Ideas Charlie???
Thanks!
