For drag racing and launching purposes, would it be best to have lowering springs in the front or stock springs? I currently have stock in front and lower in the rear. Reason behind this is the lowering spring is stiffer and that is what you want in the rear. The front I have stock, so it has more of a loose effect to help lift the front end a bit and have weight transfer to the rear. I am not looking to cut anything or upgrade to coilovers or anything.
Thanks
Jon
