Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Oil Dipstick problem. Need help.
    VIP Member Crazy8's Avatar
    Apr 2010
    North DFW
    Default Oil Dipstick problem. Need help.
    I know, I'm an idiot, but I accidently pulled my oil dipstick tube out of my engine while messing with my headers and cannot for the life of me, find the hole to put it back in. I have a GXP LS3. I climbed under a buddies GT to see where his is routed, but I guess the LS3 goes to a different spot. I can't see a hole anywhere and I can't feel a hole anywhere with my hands. It's so tight in there I can't get to a lot of places.
    Does anyone have a diagram of where it goes in at, or anyone that can describe it well enough that I can find it?
    Thanks in advance!
    09.5 LR G8 GXP A6
    For mods list, honk 3 times.
    Banned
    Jan 2009
    Chicagoland
    It goes into the oil pan, here's a picture that should help.
    Apr 2010
    North DFW
    Thanks Don. I have one of your service manuals, but I kept searching for dipstick and found nothing. I didn't think to search indicator tube LOL. There does not seem to be a hole there on my engine. I have read on some ls3's, the tube goes in on the engine block somewhere instead of the pan. If that was the case on the GXP, would the service manual for sure outline the difference?
    Thanks again for your help.
    09.5 LR G8 GXP A6
    WNY
    This is the only pic I could find and it only shows the general area...
    2009 SBM G8GT (Garage Queen)
    Apr 2010
    North DFW
    Thanks GeoffA. That's actually very helpful as I see where to stick my hands to feel around.
    09.5 LR G8 GXP A6
    WNY
    If you have Don's CD go to Document ID: 2056801 Chevy Corvette Oil tube install LS3
    Oil Level Indicator and Tube Installation (6.2L LS3)
    I don't know how to post the pics...
    WNY
    xTooltipElement
    Service Information
    2009 Chevrolet Corvette | Corvette (VIN Y) Service Manual | Document ID: 2056801
    Inspect the O-ring seal for cuts or damage. If the oil level indicator tube O-ring seal is not cut or damaged, it may be used again.
    Lubricate the O-ring seal with clean engine oil.
    Install the O-ring seal onto the oil level indicator tube.
    Install the oil level indicator tube into the engine block and rotate into proper position.
    Caution: Refer to Fastener Caution in the Preface section.
    Install the tube bolt. Tighten the oil level indicator tube bolt to 25 N·m (18 lb ft).
    Install the oil level indicator into the tube.
    WNY
    Default think I got it
    Oil tube LS3
    Apr 2010
    North DFW
    Thanks! I do have Don's cd so I will look this up when I get back home (after Xmas). Thanks for the help guys.
    09.5 LR G8 GXP A6
    Sugar Land Texas
    I believe that the LS3 and some 2009.5s L76 it goes on the block in front of the starter. I ran into this on Punishers (Fidel's) header install. It did not go through the engine mount and into the pan.
