Where are the tvs guys and turbo guys getting there catch cans from?
I didn't think there was/is a difference from the NA guys, But billet was popular. There were some billets on ebay too...
http://cgi.ebay.com/ebaymotors/GM-PO...Q5fAccessories
Heres a link...
http://shop.billetprototypes.com/pro...c?productId=77
Sent from my DROIDX using Tapatalk
Vararam CAI w/ HSRK, Stage 1 Ported Throttle Body/Intake Manifold, and a Mike Norris Catch Can
thought the boosted guys used the ones with 3
Same can, just requires slightly different plumbing depending on application.
check this out.... looks interesting.... lots of camaro guys use this.... I may end up going this way......
http://www.camaro5.com/forums/showthread.php?t=102582
Doesn't get changed at the can.
Sent from my DROID2 using Tapatalk
ooh well hell i need a how to.
stock location is nto ideal on boosted application but you can use the same can. but you will have to route the one end fo the valve cover and one before the turbo as your vac source.
