Results 1 to 5 of 5
Thread: Finally Got There
    Default Finally Got There
    ET 9.756
    139.19 mph
    1.414 60'
    After getting the car in the low 10s a few years ago I made the natural goal of going for 9s. A trail of broken parts and bad luck conspired to keep me from getting there. Today I finally broke through the barrier. First run was a 9.81. Next run was my new PB above. I could have pressed on and tried for 9.6 later in the day with even better DA, but the supercharger pulley and hub decided to separate themselves from the shaft. DA was -951 at the time of that pass. A good day at the RCR track rental.
    Friendswood, TX
    HOLY COW!! WAY TO GO MAN!!!!
    What was “different” from last year to this year?
    Shit man - that’s with the little Maggie!!! Mucho Impressive!!
    3 things were different from my previous 10.04:
    1. Lower DA, better air to start with
    2. Better traction, a better 60'
    3. Lower IATs from the PnP interchiller
    Friendswood, TX
    You’re a good coach! Hey, do you have a 4” or a 4.5” intake tubing? What is your coaching on my game plan?: 1) I ordered the TPIS 102 TB yesterday. 2). I have the RDS Phenolic plate in garage. 3) I have the PnP in garage. 4). 4” Rotofab. Suggestions/Coaching? On the right track?
    I currently have 4" intake, but going to try 5"
