Results 1 to 4 of 4
Thread: Am I missing the top two transmission bell housing bolts?
    Mar 2014
    South Fl
    Default Am I missing the top two transmission bell housing bolts?
    Is it missing the top two bolts? Im pretty sure they're missing but I've never seen this trans down before so I'm not sure of the bolt locations.
    I've noticed a rattle under load only and at 2k rpm and up. Had the transmission down for a torque converter install about 12 months before I noticed the noise. Would/could the missing bolts cause the trans to rattle against the block?
    https://youtu.be/bX7H83K2Tjo
    I don't know if it could cause the rattle, but the bolts are missing.
    Beyond Help tchr49's Avatar
    michigan
    Broken off?
    Jan 2012
    Southern California
    No way did they break off. Are you the original owner? If not I'd bet previous owner did trans work and did not reinstall the top two bolts. They are not easy. Take some effort. And if the other bolts are in place and tight I can't believe the trans would be rattling against the block.
    2008 Liquid Red G8 GT, VMS 1.5 DoD Delete and Tunes, Vararam CAI, Kooks Mid-length Headers, AEM Wide Band O2, high-flow cats, Corsa Catback exhaust, M6 conversion, MGW Shifter, GXP Diff 3.70
