Results 1 to 2 of 2
Thread: question about pinning crank
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    Default question about pinning crank
    Im thinking about switching out my 1900 for a lsa setup , If i swap the units i am going to need a new balancer am i going to need to repin the crank again once its time to switch balancers?
    Sep 2009
    VT
    Yes, LSA requires a pinned dampener. If you go ATI, it's a different orientation.
    Sport /Premium
