Not much fun putting them in by myself but got it done
Pretty cool. What are they?
R.I.P. Charlie
Spec d and legacy sells them, dunno the specific name
Looks good
If you go to legacy parts direct and look under g8 accessories they have them, just list them as led headlights though.
I see them on Legacy and I understand the built-in LED surrounds but what about the main bulbs. Any info on those? Do you re-use whatever bulbs you had?
R.I.P. Charlie
Nice and since you know how to put them in come on over I'll supply the cold Bud Light
