Locks - Key Cutting Information/Replacement Keys
INFORMATION
Bulletin No.: 08-00-89-012
Date: April 01, 2008
Subject:
Key Cutting Procedure for Obtaining Replacement Key
Models:
2008 Pontiac G8
Due to the uniqueness of the Pontiac G8 key blank special equipment is required to cut a key for the Pontiac G8. To obtain a replacement key the following procedure is suggested:
1. Obtain the vehicle key code by accessing the "Key Code Look Up" application through GM DealerWorld under the Parts tab.
2. Submit a part order through the GMSPO Parts System for a key blank. Be sure to include the key code in the "note" field of the order and indicate the preferred method of shipment (i.e. overnight etc.). Order goes to FM-REPS through SPO.
Important: The order will be shipped the same day if received by 12:00 p.m. (noon) EST, or within 24 hours - Monday through Friday.
Tip
To remove the old key from the transmitter you will need to insert a suitable tool in an opening between the two halves and pull apart.
3. Program the new key before assembly into the old transmitter. Refer to SI for Key Programming.
4. Insert the key into the ignition and turn to the RUN position.
Important: This is a one-time program meaning a key can only be programmed once. Once programmed, the key cannot be revised whether on the same vehicle or on a different one.
5. Program the transmitter to the vehicle. This can be done through the Tech 2®.
Important: As an alternate to Step 2, the following equipment can be purchased through 1-800-GM-TOOLS.
General Motors highly recommends the use of the following key machines. General Motors has identified superior equipment through testing and evaluation. General Motors believes these sources and their equipment to be reliable. There may be additional manufacturers of such equipment. General Motors does not endorse, indicate any preference for or assume any responsibility for the equipment from these firms or for any such items which may be available for other sources.
Equipment Information
Information supplied courtesy of Alldatapro.com
