Hey guys, I am having some scheduling issues with getting together with my tuner, so I've been tweaking the tune he sent me to get started. I have a couple of questions, since I think the tune isn't far off.
First, can someone explain the TCC apply tables. The rpm values on one axis, are those saying that if the converter slips by that amount of rpm that the pressure will increase to keep it from slipping?
Also, as far as lockup, what mph do most of you guys set for lockup at part throttle? I'm at 48 mph in 6th, and when I cruising I bounce right around the mph, and the converter keeps locking and unlocking. It's kind of annoying, so I'm wondering if there is any issue with setting that to a higher mph that I would mostly see on the highway.
Fwiw, I've set the part throttle slip tables to 0 already, and the tuner had already adjusted the TCC apply tables, which I do think are pretty close. I've also reduced my mph shift points a little lower to keep the car from revving to high just leaving a light.
Thanks all!
