Brand: Holden
Price: See Paul (HSV-GTS-300)
Purchased From: HSV-GTS-300 (Paul)
Description: This basically is a rear-sunshade (though some may call it a 'roof spoiler') that fits on the G8s rear window. Though the appearance may seem like a solid black it's actually transparent and probably comparable to a 15-20% tint.
Installation: Fairly straight forward though it's recommended you have some help to line everything up. Basically all you do is clean your rear window, Attach some brackets to shade, Apply primer to window, peel the protective layer off the already attached sticky tape, place shade and call it good.
Installation Time: 5-10 minutes (+4 hours of 'drying' time before driving)
Any Installation Tips You Have: Since Paul can't ship the primer that's required you'll have to buy some locally/online. It's called '3M Primer 94' and 1 little 'ampule' is all you need (costs about a dollar). You just crush the tube between your fingers right behind the brush part to start using it.
Quality of Part: 10
Product Performance: 10
Would you Recommend to Others: Definitely
Any Other Comments: It's gonna take some getting used to visually
I'll try to get some better pictures up later
