Results 1 to 3 of 3
Thread: On a road trip and need some help.
    Central Ohio
    Default Got it fixed
    Thanks
    Quote Originally Posted by BlueJacket View Post
    Took the wife's 2010 Malibu on vacation and I am having some problems. I noticed yesterday that while driving the anti theft light was on and now today the interior lights are on while driving and will not shut off. I ended up disconcting that battery so they did not drain it. I'm thinking it might be a bad battery. The car is at 60k miles with the original battery. Any other ideas?
    If the problem popped up while you were driving, I would lean more towards an alternator issue than a battery issue.
    That said, bcm issue? Loose ground connection?
    Central Ohio
    The problem started at start up. Loose ground at the battery or elsewhere?
