Results 1 to 10 of 12
Thread: finding TDC
    VIP Member mrroy61805's Avatar
    Jan 2013
    Germany
    Default finding TDC
    Did anyone actually use the proper tools when setting TDC on cam install or did you just "eye" it up.
    Lebanon,Indiana
    I know that Ray did when he installed his cam.
    Member dogcat's Avatar
    Jul 2010
    Centennial, CO
    Default finding TDC
    I think you are referring to a degree wheel and a dial indicator or piston stop if the heads are off.
    I think if you are using the stock cam gear, the dowel aligns the cam to the gear and then you just align the mark on the crank to 12 o'clock and the cam to 6 o'clock. And there isn't really any adjustment unless you are off by a tooth.
    I'm only about 90% sure on this. Probably somebody can chime in to confirm or deny my words.
    G8 GXP, Solo Axlebacks, Pat G tune, VCM CAI
    3M color stable 20%
    Jan 2013
    Germany
    im just trying to make sure before i screw my car up lol
    Quote Originally Posted by dogcat View Post
    Correct.
    Jan 2013
    Germany
    im going to get the vms 1.5 it comes with a 3 bolt cam , will the dowel still line the cam gear up?
    Quote Originally Posted by mrroy61805 View Post
    The stock L76 or LS3 has a single bolt cam & the stock timing gear has one central bolt hole to suit.
    If you install an aftermarket 3 bolt cam then you also need to change to a 3 bolt timing gear with the correct timing marks & yes it will have a dowel hole.
    2) 12586481
    Camshaft Sprocket
    • Fits LS1, LS2 and LS6
    • 4X camshaft gear
    • 3-bolt design;
    uses (3) bolts P/N 12556127
    Beyond Help DavesG8GT's Avatar
    Jan 2010
    Birmingham AL
    Ummmmmm just fyi I am trying out a new cam in my car. Pulling my VMS 1.5 cam this weekend and trying a new one with a lower LSA and a bit more grunt down low, in case you'd like to save a few bucks and buy mine. It'll be for sale once the car is up and going and I make sure the new cam is okay for my liking.
    New (cheap monthly payment car, lol): '12 Candy Apple Red Mustang GT 5.0 6MT, stock for the time being
    **SOLD **
    White Hot '09 G8 GT, Pat G tune, Pat G cam (.634"/.608", 223/230, 112 + 2), G8-4-Speed ported & milled heads, "ram air" intake, & ported TB; Reckart 90mm MAF/LS7 card, HSRK, DT headers, Rotofab, Magnaflow CB, H & R springs, stock gears & stock stall, 11.865 @ 120.32 mph, 1.941 sec 60'
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    Quote Originally Posted by DavesG8GT View Post
    LOL, I was thinking about having a bigger cam spec'd for me this spring. Power hunger never stops.
    Jan 2013
    Germany
    So how was the vms 1.5 in your opinion?
