Results 1 to 1 of 1
Thread: Pontiac G8 parts list
    Default Pontiac G8 parts list
    The definitive Pontiac G8 parts list
    Engine parts L76
    Thread here!
    Spark plugs
    Delco 41-985
    Denso ZTJ16R10
    Autolite XP5245
    Oil filters
    K&N HP-1017
    Mobil 1 M1-113
    WIX 57060
    Delco PF48
    Fram PH10060
    Magnetic drain plug
    24241872
    Engine Electrical
    ALTERNATOR & STARTER
    Alternator Assembly
    92173959 V6
    92191127 V8
    Alternator Drive Belt
    92068267 V6
    92067442 V8
    Serpentine Belt Tensioner
    12575509 V6
    12569301 V8
    Starter Assembly
    92204529 V6
    92202964 V8
    Starter Solenoid
    92204535 (All Applicable Models)
    CRUISE CONTROL
    Cruise
    Accelerator Control
    92213646 (All Applicable Models)
    Cruise Control Actuator Switch
    92204391 (All Applicable Models)
    Cruise Control Brake or Clutch Switch
    92190131 V6
    15223506 V8
    Cruise Control Module
    15819552 BCM
    12614423 V6 PCM
    92196977 V6 TCM
    12597121 V8 PCM
    Cruise Control Servo Motor
    12595829 V6 Throttle Body Assembly
    12615503 V8 Throttle Body Assembly
    Cruise Control System Controller
    15819552 BCM
    12614423 V6 PCM
    92196977 V6 TCM
    12597121 V8 PCM
    COOLING
    Cooling System
    Cooling Fan Control Module
    12614423 V6 PCM
    12597121 V8 PCM
    Cooling Fan Relay
    92199311 Each
    Cooling Fan Switch
    12566778 V6
    12608814 V8
    Electric Fan Motor
    92191944 V6 each
    92191945 V8 each
    Radiator
    92191917 V6
    92191918 V8
    Radiator Hose
    92157812 V6 Lower
    92157812 V6 Upper
    92157816 V8 Lower
    92157816 V8 Upper
    Radiator Reserve Tank
    92164620 All Applicable Models
    Thermostat
    92068018 V6 Kit
    12600171 V8
    Water Outlet or Inlet
    92068252 V6
    12600172 V8 Kit
    Water Pump
    92068267 V6
    89018052 V8
    Water Pump Drive Belt
    92068267 V6
    92067442 V8
    Water Pump Drive Belt Tensioner
    12575509 V6
    12569301 V8
    Water Pump Gasket
    12576326 V6
    12559271 V8
    BODY & HARDWARE
    Body Interior
    92196754 Glove Compartment Latch (All Applicable Models)
    92181589 Glove Compartment Lock Cylinder (All Applicable Models)
    Doors
    Door Handles
    92213438 Inner Front Left
    92213437 Inner Front Right
    92213456 Inner Rear Left with Chrome Handle
    92173773 Inner Rear Left without Chrome Handle
    92213455 Inner Rear Right with Chrome Handle
    92173772 Inner Rear Right without Chrome Handle
    Door Latch Assemblies
    92215257 Front Left
    92215256 Front Right
    92215255 Rear Left
    92215254 Rear Right
    92212791 Door Lock Cylinder (All Applicable Models)
    92181835 Door Lock Relay (All Applicable Models)
    92190192 Door Lock Switch (All Applicable Models)
    Door Mirror
    92194048 Left
    92214581 Right
    Hood
    Hood Latch
    92184170 Primary
    92202947 Secondary
    92206018 Hood Latch Release Cable (All Applicable Models)
    92176629 Hood Release Handle/Lever (All Applicable Models)
    92213657 Hood Shocks or Struts Each
    Sunroof
    Sunroof Control Unit
    92202368 Motor Assembly
    Sunroof Drain Hose
    92191853 Front each
    92191854 Rear each
    Sunroof Motor Switch
    92223695 Console Assembly
    Trunk & Fuel door
    Fuel Door Actuator & Release Cable Assembly
    92159013 or 92216665
    Trunk Latch Actuator
    92216374
    Trunk Release Switch
    92056727 (All applicable Models)
    Trunk Shock or Strut
    92213658 Each
    Suspension parts
    Front Suspension System
    Control Arm
    92183312 Front Left
    92183311 Front Right
    92183310 Rear Left
    92183309 Rear Right
    Control Arm Bushing
    92159311 Front Each
    92159305 Rear Each
    Cradle/Frame Assembly
    92159300 All Applicable Models
    Dust Cover
    92171701 Each
    Shock &/Or Strut Assembly
    92196122 Base Left
    92196118 Base Right
    Spring
    92203694 Each
    Spring Insulators
    92159317 Each
    Spring Seat
    92175171 Each
    Stabilizer Bar
    92184620 (All Applicable Models)
    Stabilizer Bar Bracket
    92171573 Each
    Stabilizer Bar Bushing
    92219337 Each
    Stabilizer Bar Control Link
    92159356 Left
    92165959 Right
    Steering Knuckle
    92201187 Left
    92201186 Right
    Strut Bumper
    90125889 Each
    Strut Cap
    92201406 Each
    Strut Mount
    92048903 Each
    Strut Mount Bearing
    92046063 Each
    Rear Suspension
    Adjuster Link
    92207139 Adjustable each
    92204885 Non-Adjustable each
    Control Arm
    92159163 Lower, Left
    92172599 Lower, Right
    92199105 Upper, Left
    92199104 Upper, Right
    Control Arm Bushing
    92172597 Lower, Inner, each
    92159149 Lower, Outer, each
    92182066 Upper, Front, Inner, each
    92182066 Upper, Front, Outer, each
    92159134 Upper, Rear, Left
    92164730 Upper, Rear, Right
    92167840 Dust Cover
    92207143 Knuckle, Left
    92207142 Knuckle, Right
    92172597 Knuckle Bushing each
    92159149 Knuckle Bushing each
    92182066 Knuckle Bushing each
    92208707 Base each
    92219907 Base each
    92171076 Shock Absorber Mount, Left
    92171075 Shock Absorber Mount, Right
    92167839 Shock Bumper , each
    92163464 Shock Cushion , each
    92171074 Spring Insulator , each
    92159179 Stabilizer Bar, All Applicable Models
    92186962 Stabilizer Bar Bracket/ Bushing
    92195849 Stabilizer Bar Control Link each
    92194094 Support Arm Assembly, All Applicable Models
    92165769 Support Bushing Lower, Front, each
    92159133 Support Bushing Lower, Rear, each
    92191989 Support Bushing Upper, each
    92159168 Trailing Arm, each
    92159149 Trailing Arm Bushing, each
    STEERING GEAR, LINKAGE & PUMPS
    Airbag System
    92191048 Airbag Contact Coil (All Applicable Models)
    Air Bag Cushion Module
    92204561 Front, Driver Side
    92202305 Front, Passenger Side
    92220646 Side, Curtain, Driver Side
    92220645 Side, Curtain, Passenger Side
    92202307 Side, Seat, Driver Side
    92202306 Side, Seat, Passenger Side
    92225702 Air Bag Sensing & Diagnostic Module (All Applicable Models)
    Passenger Control Module
    92220398 Passenger Presence Air Bag Sensor
    92219364 Passenger Seat Suppression
    92221553 Passenger Seat Suppression
    Steering Gear
    92198207 Rack Boot Kit
    92219418 Steering Gear
    Steering Linkage
    Tie Rod End
    92198273 Inner, each
    92198275 Outer, Left
    92198274 Outer, Right
    Steering Pump & Hoses
    92174214 Power Steering Pump (All Applicable Models)
    92068267 Power Steering Pump Drive Belt V6
    92067442 Power Steering Pump Drive Belt V8
    92202114 Pressure Hose V6
    92202113 Pressure Hose V8
    92202130 Steering Pump Reservoir (All Applicable Models)
    Steering Column
    92203237 Steering Column (All Applicable Models)
    92213664 Steering Column Flex Coupling (All Applicable Models)
    BRAKES & WHEELS
    Antilock Brake System
    92203497 or 92204192 ABS Control Unit
    92190130 or 92205222 or 92213570 ABS Hydraulic Fluid Reservoir
    92203489 ABS Hydraulic Unit Assembly
    24413377 ABS Lateral Acceleration Sensor (All Applicable Models)
    92203489 Pressure Modulation ABS Valve
    Wheel Speed ABS Sensor
    92211237 Includes Hub & Bearing Assembly
    24413377 Yaw Rate Sensor (All Applicable Models)
    Brakes
    Brake Hose
    92193444 Front Left
    92193445 Front Right
    92193450 Rear each
    Brake Pads
    92206845 Rear
    Caliper
    92193439 Base Front Left
    92193440 Base Front Right
    92193448 Base Rear Left
    92193451 Base Rear Right
    Caliper Kit
    92193443 Front Seal Kit
    92193449 Rear Seal Kit
    Disc Rotor
    92188884 Base Front Each
    92170767 Base Rear Each
    Master Cylinder & Reservoir
    92204975 or 92213566 Master Cylinder
    92190130 or 92205222 or 92213570 Reservoir Kit
    Parking Brake Cable
    92191008 Front
    92190859 or 92220641 Rear Left
    92190860 or 92220642 Rear Right
    Parking Brake Lining Kit
    92196003 (All Applicable Models)
    Power Brake Check Valve
    92190135 (All Applicable Models)
    Wheels
    Tire Pressure Module
    RCDLR,ID # 25808838 15819552
    RCDLR,ID # 25852909 25852909
    Tire Pressure Reset Switch
    92217146 or 92219491 Driver Information Center
    Tire Pressure Sensor
    15922396 Each
    Wheel Bearing
    Front (Serviced in Front Wheel Hub)
    92171057 Rear each
    Wheel Hub
    92192305 Front each
    92206974 Rear each
    DRIVESHAFT & AXLES
    Propeller Shaft
    92157726 V6 Assembly
    92157731 V8 Assembly
    Rear Driving Axles
    Axle Seal
    92191956 Left
    92191957 Right
    Axle Shaft Assembly
    92191888 V6 Left
    92191887 V6 Right
    92191886 V8 Left
    92191885 V8 Right
    Axle Shaft Boot
    92189148 V6 Inner each
    92189147 V6 Outer each
    92189153 V8 Inner each
    92189152 V8 Outer each
    Axle Shaft Joint Kit
    92189146 Inner each
    92189145 V6 Outer Left
    92189144 V6 Outer Right
    92189150 V8 Outer Left
    92189149 V8 Outer Right
    Differential Assembly
    92157701 V6
    92157714 V8
    92216388 V8
    Body Parts
    Tail lights
    GT
    92202361 LH
    92202362 RH
    Sedan
    92202359 LH
    92202360 RH
    Splash Guards, Contour
    92215232
    GM Accessories
    92207098 Cargo Area Organizer Black w/ V-Crest Logo
    92207096 Cargo Area Tray Black w/ V-Crest Logo
    92214933 Door Sill Plate Kit Front and Rear Set, Bright Stainless Steel w/ G8 Logo
    88960626 First Aid Kit Black Vinyl w/ GM Logo
    92213585 Floor Mats, Carpet Front and Rear Set, Black w/ V-Crest Logo
    92208706 Fuel Door Chrome w/ G8 Logo (w/ RPO Code XQ3, DNR)
    12497328 Highway Emergency Kit Helps You Get Back On The Road
    92213827 Interior Trim Kit Instrument Panel and Steering Wheel Inserts
    92207239 Luggage Carrier Bright Finish w/ Black End Caps
    12497374 Mobile Office Organizer Held In Place w/ Seat Belt Restraint
    92214921 Outside Mirror Covers Chrome (Set of 2)
    92214916 Pedal Cover Brake and Accelerator, Brush Aluminum
    92214353 Rear Object Sensor Package Black (80U)
    92214359 Rear Object Sensor Package Blue Green (64U)
    92216530 Rear Object Sensor Package Bright Red (26U)
    92214358 Rear Object Sensor Package Dark Blue (39U)
    92214354 Rear Object Sensor Package Dark Gray (18U)
    92214357 Rear Object Sensor Package Medium Red (62U)
    92217165 Rear Object Sensor Package Silver (17U)
    92216389 Rear Object Sensor Package White (11U)
    92213204 Remote Start 2-Way Advanced Remote Start (w/ RPO Code A90, V7P)
    88960625 Roadside Assistance Package Helps You Get Back On The Road
    92206987 Shift Knob Black w/ V-Crest Logo
    92206988 Shift Knob Red w/ V-Crest Logo
    92215305 Smoker's Package Ashtray, Black
    92215232 Splash Guards, Contour, Set of 4 Front and Rear Set, Black w/ V-Crest Logo
    92216309 Stripe Package Black (Hood, Front Fender and Rear Fender Stripes)
    92216310 Stripe Package, Front and Rear Set Silver (Hood, Front Fender and Rear Fender Stripes)
    92216313 Stripe Package, Rear Set Black (Rear Fender Stripes)
    92216314 Stripe Package, Rear Set Silver (Rear Fender Stripes)
    12495014 Visor CD/ DVD Holder Holds up to 12 of your favorite CDs or DVD's
    Part information contributors: HSV-GTS-300 (Paul), Grrrr8 (Charlie) Greg@Paceperformance, silver6.0L
