Results 1 to 5 of 5
Thread: Headers install
    Member whitegt's Avatar
    Dec 2015
    Default Headers install
    Have any of you guys installed your headers yourself?
    Senior Member imajeenyas's Avatar
    Mar 2013
    I did...extremely easy while the heads were off.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Sep 2009
    VT
    Many have and shared the experience.
    Best to use google to search, type the following string in google: header install site:grrrr8.net
    I suspect the search will answer most, and likely all of your questions. It's easy, can be done on jackstands with one person.
    Sport /Premium
    Dec 2015
    Ok thank you guys for the help.
    Lebanon,Indiana
    yes,not bad. just MARK steering column before removing. straight forward after that. If I remember correctly the drivers side O2 needs extended
