Results 1 to 7 of 7
Thread: G8/Camaro Alignment Tech Sheet
    Vendors Rob@WretchedMS's Avatar
    Enfield, CT
    Default G8/Camaro Alignment Tech Sheet
    http://www.wretchedms.com/v/vspfiles..._Techsheet.pdf
    This may be updated fairly quickly, but i wanted to get this out before heading to bed for the night.
    This is a tech sheet you can print out and bring with you to get your car aligned, it has the OE specs and my own specs on it.
    There are notes about things for the tech to watch for, and it's formatted in the proper way for doing an alignment.
    If i've screwed something up let me know, i ain't the best speller all the times, lol
    Enfield, CT
    updated
    Cambridge, MA
    Thanks very much for this alignment spec sheet. I have the Track II package installed with the drop springs. I will be getting the rear camber bolt kit and front caster kit soon. Are those bolt kits the same as the "HD Bolt Kits" you mention in the spec sheet for using the Wretched Specs?
    Will I be able to achieve all the specs under the Wretched Specs Performance Street with everything I just mentioned installed?
    Thanks.
    Cambridge, MA
    Also, do you currently have the G8 PDUSAG8FULL G8 Full Alignment Kit in stock?
    Enfield, CT
    I do not have the full kit in stock, but i do have the rear kit, and the front washers, the price is the same, and you achieve the same results.
    Typically when you adjust the caster you want to max it out, so whether you use offset washers or the bolts to achieve that is no different.
    I just posted my newest tech sheet in the other thread, it's on how to properly time your bushings if you lower the car, this is more prevalent with OE bushings with bonded ferrules than with Pedders bushings, but it's good info either way.
    Enfield, CT
    Bump for those that need it.
    Would be great as a sticky.
    Clayton, NC
    [QUOTE=Rob@WretchedMS;398703]Bump for those that need it.
    Would be great as a sticky.[/QUOTE]
    Ditto!
    RIP Charlie, The GRRRR8 One
    [SIZE="2"][COLOR="Red"]
