Results 1 to 7 of 7
Thread: Changing spark plugs
    Member RuLEoF2's Avatar
    Jul 2014
    Default Changing spark plugs
    Sorry if this has already been covered but I searched a bit and nothing looked obvious.
    So, I just bought a set of spark plugs and I was wondering if there is a recommended procedure for this car. I know from what I can see and what I've read that the passenger side is a real PITA to get to. I've changed plugs on other cars so I'm knowledgeable on the basics.
    Any tricks or tips would be much appreciated. Thanks.
    Current:
    2016 Chevy SS - "Some Like it Hot" Red Metallic
    Previous:
    2009 G8 GT - Sport Red, Sport Package, Vararam CAI, Borla Exhaust
    N.O.LA
    Getting to the passenger side firewall plug appeared to be problematic initially, but my plug socket had a 19mm nut shaped head IIRC making that plug easy once you get it started correctly by hand. I always change that plug first, originally used the plug socket with a 3/8 shallow socket, but now use a 19mm flex head ratchet wrench making it even easier to extract that plug.
    I run copper plugs, change them about every 9k miles and do not remember having any other difficulties. Oh, a plug wire removal tool also comes in handy.
    JAM
    VIP Member donkeyGT's Avatar
    Dec 2010
    Jenison, MI
    +1 on the flex head ratchet.
    Jul 2014
    Quote Originally Posted by JAM View Post
    JAM
    A flex head tool makes a lot of sense. I was thinking of using a swivel but was concerned that there wouldn't be enough clearance. So, to clarify, you're talking about something like the image I attached?
    Current:
    Previous:
    N.O.LA
    Precisely!
    JAM
    After using a wobble extension for the first t8me last year, I bought a set. They're awesome.
    Plus, they make socket insterts that give you a bolt head to put a wrench on. Awesome.
    The far back one on the pass side? I put a socket over the spark plug socket. Makes for a straight shot with the ratchet.
