Results 1 to 8 of 8
Thread: 92 Bonneville Front End Shimmy
    Default 92 Bonneville Front End Shimmy
    My 92 Bonneville has a slight shimmy. It's been around for quite some time, and I thought it was just the tires. I got new tires a couple weeks ago, and the shimmy did not change. It's not very severe, just kinda annoying. It's in the front end, though the steering wheel doesn't really want to go back and forth side to side much, it's more of an up/down kinda feel. It shows up at 40-50 mph, and calms down some above 75. I thought about having a bent wheel, but the tire guys didn't say anything. I can feel it in the steering wheel, and in general in the body too.
    Senior Member scorpion's Avatar
    Jun 2012
    Armpit of America virginia beach
    I had the same problem with my 99 ssei and it was a cv shaft. Don't know which one cuz I replaced both of them.
    Not saying that's your problem. But just an idea where to look
    2009 LR G8 GT
    Varraram intake, LS7 maf, SLP underdrive pulley, granatelli 0 ohms resistant 10.5 wires and coil packs, PYPES 1 3/4 tri y long tubes, OBX x pipe no cats, flowmaster 44 with 4" quad tips, camaro 3.45 rear end, BC coilovers, BMR lower control arms, BMR tow rods, BMR trailing arm, BMR subframe connectors, BMR tunnel brace, BMR strut tower brace, BMR front sway bar, BMR rear sway bar, spyder rear tail lights, powder coated black camaro rims
    6.2L engine swap
    Rick Crawford special
    Ported polished and milled heads (11.6:1) with LS9 valvetrain, Rickifast intake, Rickifast throttle body,DOD delete,CTSV racing lifters, 111 lunati cam, 3000 triple disk coan stall
    2011
    yellow ctsv brake upgrade
    Well, the left CV has had a pinhole in the boot for years, and very slowly splooges grease. I dabbed with JB weld more recently, and it seems to be holding.
    Sugar Land Texas
    Check engine mounts 1st. A worn or sagging engine mount will cause this issue and eventually lead to a damaged CV shaft.
    They've actually all been replaced during an engine swap that post-dates the shimmy.
    Jun 2012
    I still say replace cv shafts
    2009 LR G8 GT
    6.2L engine swap
    2011
    Update:
    I've replaced the CVs, ball joints, tie rods (inner and outer), wheel bearings, endlinks, and calipers, and the shimmy persists. I'm going to take it in for an alignment and ask them to double check the wheel balance and if there are any bent wheels.
    It comes around 50 mph, and fades around 70. And it seems to flare up a little when off the gas and coasting. I've ordered new ignition coils to hopefully rule out a slight misfire. Mine are MSD's that are maybe 10 years old that I bought used.
    Beyond that, any more ideas?
    Sep 2011
    I think you have a bad balancing or bent wheel
